Manual CCT
  • TomB
    • Aug 2006
    • 967
    • Cumbria, UK
    Manual CCT
    For those who may want to go manual with the CCT.
    Tom
  • TomB
    • Aug 2006
    • 967
    • Cumbria, UK
    Looks like it would fit better
    Tom
    • Aches n Pains
      • 349
      • Reston, Va.
      Put a manual adjuster on my Kawasaki Police Special and have never looked back. That way I can keep it quiet myself.
      1995 KZ100P
      Pods, jets, pipes, cam adjuster, oil cooler
      1977 Ironhead - custom build
      Hot engine, custom frame, KZ front and rear, high torque starter, alternator conversion, Progressive shocks, Thunderheart wiring, Dyna ignition, oil cooler, Dakota Digital instruments, etc.
      Sold all my XS's to Eastcoaster but still love to keep up with you guys. This is the best cycle forum on the web.
        • 3918
        "The automatic adjusters can back out when the throttle is closed suddenly at high rpm. This allows the cams to go momentarily out of time, and can result in bent valves and/or serious engine damage. "
        Is this true or common?
          • 7942
          I don't see how. The one I put on my bike is a ratchet device. It's going to have to break and suffer catastrophic failure for the chain to get loose. I suppose it could happen, but Yamaha put these in an awful lot of machines. I'm not concerned about that.
          This is most likely to happen with the stock tensioner. It's going to get loose if the pinch bolt slips.
          • James England
            • 3039
            • North of England
            It's the manual ones that can be prone to that. The Vmax auto I used has a serious non-return ratchet on it.
            • TomB
              • Aug 2006
              • 967
              • Cumbria, UK
              Sales pitch and BS really.
              Used correctly the OEM tensioners are perfectly OK, some folk like the fit and forget of the auto tensioner which is cool. Some hands on engineering types (control freaks) like myself like manual tensioners.
              I worked on 80's Kawasaki's with auto tensioners that gave lots of trouble so I'm biased against them, the Yam ones may be OK.
              Anyone have old car ratchet brake self adjusters that wear and back off when you don't want them to? Got sick of having to adjust them up and weld them in place to pass the annual vehicle safety inspection?? (MOT in UK)
              Yes anything manual needs you to do work, I do mine once a year whether it needs it or not (15 min job), thrash my engines and have never had any cam chain problems.
              The choice is yours, but do it for YOUR reasons, not because everyone else is doing it
              Tom
