Just want to clear up that 12.4 volts is only half charged. If a battery sits like this it will sulfate and die a premature death. 12.6+ is fully charged, resting voltage. Bikes tend to undercharge a bit on idle so every ride can leave you with a charge deficit which can add up.
Keep it on a tender or check the voltage regularly before you ride. If you check just after your ride you will be reading a surface charge. Let the battery rest for a while at least before you check the voltage. If it's below 12.6 trickle charge it for 14-16 hours.
