Strange electric thing poped up
  • Jeffintampa
    • Apr 2011
    • 344
    • Zephyrhills, Florida
    HI all.
    Strange thing is happening hope you can help. I drive the bike every day and always starts fine. Jumped on today and battery was deadish, rolled over and then stopped, I cleaned up all the connectors positive and negative. Put a charge on battery, started it up a couple times, then just now 1-2 hours latter, got on and nothing again.
    Please give me some ideas and what to do pleassssseeeee
    Bike History:1980 XS 1100 special current bike
    1980 XS 850 special wife sold
    Originally posted by Jeffintampa
    HI all.
    Sounds like it's telling you time to clean some connections and contacts.
    IIRC, 80 and later right bar controls grounded thru bars, but I could be off a year. I know ALL 81 models did.
    Corroded START button contacts......
    Would also be a good idea at this point to pull right sidecover, unscrew fuse panel mount to access the plug-ins behind it. Unplug and spray Deoxit cleaning contacts on ALL those plug-ins.
    Fully charged, load testing that battery will help determine its condition, as it kinda sounds like at this point there's a good chance connections associated with charging system may not be as good as they need to be, since you state it gets started and ridden daily.
    • Jeffintampa
      • Apr 2011
      • 344
      Dang it
      got it started went for a ride around town and shut off and almost dead woundnt restart low battery. Feels and acts like I have a leak in the electrical.
      any ideas
      battery is not that old.
      • Jeffintampa
        • Apr 2011
        • 344
        clean up
        I took both battery cables off and sanded them shiney and the cable ends, and the frame ground. in the fuse area I took off both the 10 mm nuts shined them up. gonna see if it charging and let ya all know the numbers.
        • Jeffintampa
          • Apr 2011
          • 344
          its charging
          Well,
          fired it up throwing 12.4-12.5 on idle, 2 grand 13.4-13.6 3 grand 14+ 4 grand 14-15.
            Hi Jeff,
            Your charging system is working so on to the next thing. Sometimes even a fairly new battery can go bad. Try charging it then disconnect it from the bike and leave overnight (12 hours) then check voltage again. If it gives the same reading you know the bike and not the battery is the problem area. Or if available a Load Tester will answer the question.
            • Jeffintampa
              • Apr 2011
              • 344
              Thanks
              I looked it up the battery was put in 10/27/13 year and a couple months could be shot been charging on 5amps over night will disconnect and see whats up
              thanks
                • 4015
                Whoa! I thought bike batteries are supposed to be charged @ 1a? Take it to Auto Zone, etc., and have them load test it.
                • foreda
                  • 949
                  • Southwest Louisiana
                  Battery
                  My bet is on the battery. Charge it up and then take it to your local parts house and have them load test the battery.
                  78 XS1100E Standard
                  Coca Cola Red
                  Hooker Headers
                  1979 XS1100 Special
                  1980 XS Standard
                  2006 Roadstar Warrior
                  • vedgar
                    • 311
                    • Clarkston, Michigan
                    5 amps ?
                    I think you killed it, if it was not near death already .
                    79 1100 SF Carmine Red stock
                    85 Honda v65 Magna
                      • 2117
                      Do you have one of those batteries that you need to add distilled water to bring the fluid up to the line? Not acid but distilled water.
                      • Jeffintampa
                        • Apr 2011
                        • 344
                        took it out
                        I took out the battery today and it showed 13.5 amps in the morning, checked it tonight and its 12.4
                        • Jeffintampa
                          • Apr 2011
                          • 344
                          checked water
                          Yes it is the levels looked ok I added maybe a tablespoon to the battery in 2 cells
                            • 2117
                            Your voltage shows normal-what is it cranking?
                            • Jeffintampa
                              • Apr 2011
                              • 344
                              Thanks
                              I have it out thinking about taking for a load test.
