Fun with lifter
    Most motorcycle shops that have a service department that's been there a while will probably have some. Yamaha wasn't the only bike to use these, (Jaguar cars did as well) but I would bring a set of calipers with you to measure the shim. There is also a 29.5mm shim out there that you can't look at and tell the difference. You can't even hold it next to a 29mm and tell. It just won't..... quite... fit... in that bucket.
    There used to be a shim library out there that Maximan donated when he left. Anyone seen/heard from it in a while? Last I remember, going off a terrible memory and often wrong, seems I remember Kat sending it to Kurt (Prometheus) up in Washington? He doesn't post here any more, but a lot happened during that time and I wasn't around here. Not trying to scratch up any wounds at all.. just asking about the shim library.
    • Wildkat
      XS Special Gurette
      • Apr 2004
      • 3416
      • Location, Location
      Nothing left of the one cody left except the shim sizes nobody needs anymore. Not sure where that set ended up as I sent it off to another member when I left as mod. Prom donated his own set and it is no longer available.
      81 SH Something Special
      79 SF MEAUQABEAUXS
      81SH Nor'eas tah (Old Red)
      80 LG Black Magic
      78 E Standard Practice
      James 3:17
      “Alis Volat Propriis”
      Yamaha XS 1100 Classic
      For those on FB
      • mack
        • 2411
        • Ontario, Canada
        shims
        Let me look around, I may have a 265 and 270.
        mack
        79 XS 1100 SF Special
        HERMES
        original owner
        81 XS 1100 LH MNS
        SPICA
        78 XS 11E
        IOTA
        https://youtu.be/wB5Jfbp6SUc
        https://youtu.be/RaI3WYHSuWA
        Frankford, Ont, Canada
        613-398-6186
        • mack
          • 2411
          • Ontario, Canada
          Shims
          I had three spare heads here and just went through them. The third one of course had what you needed. PM me your address and I'll send a 265 and 270 to you.
          mack
          HERMES
          original owner
          81 XS 1100 LH MNS
          SPICA
          78 XS 11E
          IOTA
          613-398-6186
            • 7765
            I can check and see what I have in my "spare" bin. I'm at work today, but if I can help, let me know via pm.
            • RichV
              • May 2013
              • 374
              • Everywhere
              Thanks everyone. Someone responded to my request for help and is sending me the two shims that I need.
              _________________________________________
              1981 XS1100SH (Lola) - Bright Cardinal Red
              Whatever Lola wants, Lola gets.. Don't mess with Lola.
              Mostly stock with a few minor upgrades
              1981 XS11000SH being used for parts (Sold off)
              Also have:
              2009 Harley Davidson FLSTC with over 120K miles. All mine.
              Currently traveling the country with an aluminum can in tow and a motorcycle in the truck bed in search of the perfect road.
