Rear Axle tightening
  • gene
    • Mar 2009
    • 267
    • Weston, Fla.
    Is there a simple step by step process for tightening up the rear axle?
    Gene (Florida)
    1980 XS1100SG
    Accel Coils
    4-1 Jardine Exhaust
    Stick the axle in with everything in place, torque the axle nut, then the pinch bolt.
    I don't have the numbers though.
    • gene
      • Mar 2009
      • 267
      • Weston, Fla.
      Is it ok if the hole is partially covered on the brake side? I started to tighten the nut and when I went to put a bar in the hole to torque the nut, the hole was partially covered.
      Gene (Florida)
      1980 XS1100SG
      Accel Coils
      4-1 Jardine Exhaust
        • 8052
        Put the parts on in order. The nut will be on the left side of the bike. I don't know the specified torque, so I won't put it here. It's in the neighborhood of 100 ft lbs. The Clymer book lists the wrong torque. Advance the nut to where you can pin it. Finally, torque the pinch bolt on the right side.
        • vedgar
          • 311
          • Clarkston, Michigan
          Torque for rear axle
          108 ft lbs axle nut and 14.5 for pinch bolt
          79 1100 SF Carmine Red stock
          85 Honda v65 Magna
            • 8052
            Yes, it is OK if the hole is partially covered. The axle itself will pull everything together. The right side of the swingarm falls where it may and the pinch bolt is tightened.
            • gene
              • Mar 2009
              • 267
              • Weston, Fla.
              Got it. Thanks guys.
              Gene (Florida)
              1980 XS1100SG
              Accel Coils
              4-1 Jardine Exhaust
