Serious issues
  • mack
    • 2411
    • Ontario, Canada
    cases
    Tom, very intuitive. They aren't as bad but still above. I just measured with a feeler guage and the lowers are just under .05 mm and the uppers are closer to .04 mm, the only one that seats flush is the side thrust bearing but it's counter part is 0.05 with a feeler guage.
    Is it possible to to use a sheet of emery paper and rub the overhang off? I can't use the originals as several are down to the copper and a couple have deep gouges in them! When I first took it apart I found a lot metal fragments in it. Now I know from where they came.
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
    • TomB
      • Aug 2006
      • 967
      • Cumbria, UK
      Again its not something I would do, the shells should fit and be the right size.
      For something that needs a full strip if you're wrong I'd be looking for good fitting shells.
      Tom
        Mack, you may be chasing your tail on this one. First, there's only a few ten thousandths difference in size between those various 'color' bearings; Yamaha used these to 'select fit' bearings to get as close as possible to optimum clearance. I'd be surprised if the 'range' of these from smallest to largest is more than .001". The issue for you is you don't have measuring tools that read that down that fine. Keep in mind that the difference between .044 mm and .051 mm is only .0003", beyond the accuracy of plastigage. This is why Yamaha had that elaborate numbering system for the crank/cases/bearings; few (if any) shops would have the tools needed to actually measure these differences. Note that Yamaha also doesn't give either bearing bore or crankshaft journal diameters; they assume that if you can't reach proper specs, the crank is worn and must be replaced.
        Second, that fact that the new bearings stick up is probably 'normal'. All the bearings I've ever worked with have this, and the reason is 'bearing crush'. The idea being is that once everything is torqued down, this forces the bearing into full contact with it's saddle, giving the bearing a fully solid surface to work against as well as helping with heat transfer (very important). The 'old' bearings have been 'set' into the bores from use and won't display this as much, maybe not at all.
        Lastly, you mention that these cases have been in a fire, but it wasn't hot enough to damage the paint. Well, the bummer is that aluminum is much less stable compared to cast iron, and exposure to temps above about 350F for long periods can cause dimensional changes. You may have bad cases, and attempting to remachine them will be an extremely difficult task. Not very encouraging..... sorry....
        • mack
          • 2411
          • Ontario, Canada
          So
          here I am, whats the concensus. Put it back together with the blues and hope for the best? If the motor is toast whats the difference. Blow now or blow later. Maybe It won't blow at all or maybe it will take 50K.
          What would you do?
          mack
          HERMES
          original owner
          81 XS 1100 LH MNS
          SPICA
          78 XS 11E
          IOTA
          613-398-6186
          • TomB
            • Aug 2006
            • 967
            • Cumbria, UK
            What Steve says about the shells is repeated here
            I would have a go at assembling up the cases with the shells in slowly winding the bolts down to see if they sit in better until the case gap is closed, if you wreck the shells then they were no use anyway, better to find out this way than build it up and find out they're no good when you hit the starter button.
            The reason I said how are the top case shells was I was hoping they were going to be under flush, that way when the whole lot is closed you will have a perfect circle in the bearing.
            Steve's point about the cases being heat damaged can be checked by pulling the cases up empty using all the bolts, if they close up they are OK to use. And folk regularly get cases powder coated at 350F, if it warps them a little (read this as annealing them allowing them to relax a little) no one seems to have trouble rebuilding the motors.
            If you have any doubts about the cases being warped dry build the gearbox into them and see if this spins up Ok.
            Tom
              I'll agree with Tom's idea of dry-fitting the cases to see if everything still fits. I'd even install the crank (minus the rods) and see how easily it spins. Generally, too loose is better than too tight, and you may be able to compensate for this with oil weight; although what effect this may have on the clutch is hard to say. Being 'over spec' by only .0003" shouldn't be a deal breaker. The motor may not last as long as a factory new assembly, but will likely last longer than however many miles you may put on it.
              As to the possible warp, most heating done for coating purposes wouldn't cause that much movement. But you don't know just how hot yours got; at what point does that paint break down? 400F? 500F? And how was it cooled? If in the course of putting out the fire this was sprayed with water, you may be suffering from uneven cooling.
              If a 'dry fit' doesn't show any obvious issues, I'd be tempted to put it together and run it. The only place I'd be real concerned about the case halves not pulling 'tight' would be if it's at the main bearing saddles; if it's there, you will have issues with the bearings. I know you're trying to keep it 'numbers matching', so you really don't have that much to lose.
                What would you do?
                Those bearings together will make a perfect circle. Throw it together with some sort of assembly lube on the bearings and ride the he** out of her. And make sure there's no lube or oil on the BACK side of the bearings before installation.
                Umm.. You are getting an auto tensioner and swapping the washer on 2nd gear, right?
                • mack
                  • 2411
                  • Ontario, Canada
                  Big
                  the 5 th and 2cd have been back cut and the washer has been swapped. I'm going with a vmax CCT as from what I understand the holes match up perfectly. Brand new cam chain as well.
                  mack
                  HERMES
                  original owner
                  81 XS 1100 LH MNS
                  SPICA
                  78 XS 11E
                  IOTA
                  613-398-6186
                    ...I'm going with a vmax CCT as from what I understand the holes match up perfectly....
                    Not all of these fit perfect either; I had to lightly file one of mine in order to screw the bolts in by hand. But these are a lot closer than the other ones....
                    • mack
                      • 2411
                      • Ontario, Canada
                      Update
                      my wife finally passed me her flu so I haven't been over in the shop for awhile. I did marry the cases together and the mating surfaces are outstanding. I ran into a old friend in the mall who builds and races drag stuff, flat bottom boats, old trucks and yes motorcycles. I was telling him of my issues with the plastiguage and he laughed.
                      Basically he confirmed everything that was said in this thread. Using plasti guage on new bearing shells is a waste of time and plastiguage. The shells are designed to stick up a bit and crush into place to: fill in any iregularity in the saddles and to stop the shells from spinning with the shaft. Plastiguage is for testing existing shells to see if it's time to jump colours.
                      So long story short. I WAS chasing my tail. I'm back in the game as soon as I can stand up without sweating, and feel confident that more than five feet from a toilet is achievable in both time and distance.
                      Thanx for all the help. Merry Xmas one and all.
                      mack
                      HERMES
                      original owner
                      81 XS 1100 LH MNS
                      SPICA
                      78 XS 11E
                      IOTA
                      613-398-6186
