Frame Measurements
  • TheRev
    • Jun 2012
    • 235
    • Madison, Wi.
    Frame Measurements
    I am trying to build a powder coat oven but I don't have a good idea of the measurements of the xs1100 frame. If someone has a bare frame would you mind measuring it for me? My plan is to build the oven like a horizontal box and load it from one end. So I would need the height, width and length. Thanks
    1979 xs1100f
    New Fuse Box
    Progressive Shocks
    Gold Valve Emulator
    Dyna Coils
    Electronic Flasher
    Led Headlight
    Led Turn Signals
    4 Led Driving Lights
    2nd Gear Fix
    Auto Cam Tensioner
    Digital Dash
    Stainless Braided Lines
    R6 4 Piston Calipers
    Stainless Bolt Kit
    Maier Fairing
    Dyna Balancing Beads
    Spin On Oil Filter
    Stebel Nautilus Horn
    Plasti Dip Rims
    ISO Grips
    • 7830
    Give me three hours to get off work, and home. I have a '79 standard frame that I'm prepping for a "newer" engine, and can measure that for you. Don't forget, you should have at least 3" all around for airflow and to keep any cold spots down! Powder coat requires a certain temp profile to adhere properly!
      • 7830
      OK, I'm home.
      16" wide, 56" long, and 24" tall should just fit. I fudged about an inch or two all around. This is a 1979 STANDARD.
      I would try and make the oven 24"X30"X60" at the minimum, so you have airflow and few cold areas. Good luck!
      • TheRev
        • Jun 2012
        • 235
        • Madison, Wi.
        Hi Ray
        Thank you so much for the measurements. I have a 79 standard as well that I rebuilt. I am thinking about getting another one and begining a rebuild again. I fugured a xs1100 has a large frame and if I make an oven that can accomidate a xs1100 frame it should be big enough for other bikes in the future. Thanks again.
        OK, I'm home.
        1979 xs1100f
        New Fuse Box
        Progressive Shocks
        Gold Valve Emulator
        Dyna Coils
        Electronic Flasher
        Led Headlight
        Led Turn Signals
        2nd Gear Fix
        Auto Cam Tensioner
        Digital Dash
        Stainless Bolt Kit
        Maier Fairing
        Spin On Oil Filter
        Plasti Dip Rims
        ISO Grips
          • 7830
          No problem. I will NOT powder coat a frame because of the ocean. The salt air causes rust to form in ANY defect or scratch, and it will not show up until large parts of powder coat flakes off. I've been through it ONCE, so no more. I paint my frames, and have to send out of state to get good paint now....
          • TheRev
            • Jun 2012
            • 235
            • Madison, Wi.
            Good point on the salty air. I live in wisconsin so I don't have that problem. What stinks for me is I can only ride a few months out of the year. I would love to live where it's warm so I can ride all year. Thanks for the help.
            1979 xs1100f
            New Fuse Box
            Progressive Shocks
            Gold Valve Emulator
            Dyna Coils
            Electronic Flasher
            Led Headlight
            Led Turn Signals
            2nd Gear Fix
            Auto Cam Tensioner
            Digital Dash
            Stainless Bolt Kit
            Maier Fairing
            Spin On Oil Filter
            Plasti Dip Rims
            ISO Grips
