Starter clutch
  • mack
    • 2411
    • Ontario, Canada
    Starter clutch
    I had mine soaking in metal rescue for the last three days to get some of the rust off it. Turned out pretty good but my question is do you oil the rollers during assembly, or do you leave them dry and let the system oil it after start up?
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
    I don't think it'll matter either way really. A little engine oil probably wouldn't hurt. You did get a rebuild kit right?
      Hey Mack,
      Like Greg said, since you're that far down into the engine, replacing the old pinch rollers/springs with new ones from a kit would be advisable, especially since you say there's some RUST on the assembly, possibly some on the rollers as well. The rollers are supposed to be fairly smooth and not pitted.
      The kits are relatively cheap from PNM and such, about $10.00 IIRC.
      I would also suggest checking out the actual starter shaft that the pinch rollers GRAB....check for grooves and such. A fellow IIRC from South Africa who was a TRAIN engineer of sorts posted in an email to the admin account about a starter clutch in his bike that was skipping, not grabbing. When he tore it down....he found the starter shaft damaged with grooves and such. He chucked it in his LATHE and smoothed it out, and then put it back together, and said it was working just great afterwards. JAT!
        Partsnmore is $28 for the kit, but not sure on their shipping any more. Mikesxs has them as well for $30, but don't know shipping there either.
        But yeah, that shaft they pinch needs to be nice and smooth.
        And a light coat of oil might help keep it from rusting again until you get it back together.
