Valve cam clearance
  • LoHo
    • Sep 2002
    • 1342
    • Fresno, CA
    Valve cam clearance
    In my Clymer's, page 44 gives the clearances as .21-.24mm exhaust, .16-.20mm intake.
    On page 56, it states .01-.04mm intake, .025-.55mm exhaust.
    What the hell?
  • rover
    • Jan 2004
    • 765
    • central WI (715)
    valve clearances
    The first group you have listed should be in inch decimals (thousands of an inch). The second group is in millimeters. These appear to be correct.
    put something smooooth betwen your legs, XS eleven
    79 F (Blueballs)
    79 SF (Redbutt)
    81 LH (organ donor)
    79 XS 650S (gone to MC heaven)
    76 CB 750 (gone to MC heaven)
    rover has spoken
    • Prisoner6
      • Aug 2013
      • 1184
      • Phoenix, AZ
      Hey, LoHo -
      Don't have the Clymer's manual in front of me right now, but I do know that the correct valve clearances (measured with the engine stone cold) for the 1980G in your signature should be:
      Intake - .11-.15mm (earlier models were .16-.20mm)
      Exhaust - .21-.25mm
      Hope that helps ...
      Marco
      1979 Honda CBX
      2002 Kawasaki ZRX1200R
      WE MISS YOU, DON
      • Ken Talbot
        • 4251
        • Revelstoke, BC
        Ignore the table on page 56 - it looks like it was done by somebody who was having a bad day. The info on page 44 corresponds with the info in the quick reference section on page v11 at the front of the book - stick with that. I cant imagine how noisy an engine would be with exhaust valves at 0.55mm!
        Ken Talbot
          • 9981
          Valve clearances in inches......
          intake (78 - 79) .006 - .008
          intake (80 and up) .004 - .006
          exhaust all years .008 - .010
          • LoHo
            • Sep 2002
            • 1342
            • Fresno, CA
            Yeah Ken, those are so far off that they must mean something else, although I can't think of what. The "0.01-0.04mm" for the intakes is what got my attention. Just a little bit of wear would cause the intakes to be open almost throughout the cycle. I actually bought another set of gauges because none of the ones I had went at low as .04mm. I have adjusted them correctly before, but used this site as my guide.
              • 9981
              Tune up specs on page VII in the front of the Clymers.
              • ViperRon
                • Feb 2011
                • 1062
                • Woodstock, VA
                In doing this adjustment it is very important not to mix oranges and apples. The metric mm feeler gauge setting is very different from inches. Thousandth's and mm are very different so for the non mechanic its very important to not let this confuse a person. Most gauges have metric one side and inches the other. the specks given by Greg Ba80 are thousandth's what I use and are correct. It is very hard to get all at like .006 since the shims are in 5 mm increments about .002 thousandths. More often you will have one you either have it at .007 or .005 and can not get .006 as long as you are within the spec .006-.008 it will run fine.
                Rodan
                1980 G Silverbird
                1198 Overbore kit
                Grizzly 660 ACCT
                Barnett Clutch Springs
                R1 Clutch Fiber Plates
                122.5 Main Jets
                ACCT Mod
                Mac 4-2 Flare Tips
                Antivibe Bar ends
                Rear trunk add-on
                  • 9981
                  You'll want to set them on the wide side anyway Ron. They will close up as they wear. I have one intake that ended up a little too wide and is noisy when the oil thins but is getting quieter as I put on miles.
                  • LoHo
                    • Sep 2002
                    • 1342
                    • Fresno, CA
                    I am kosher with the inches verses mm; what stunned me was the numbers I saw in the spec list. I replaced three bent valves after f***ing up the ACCT (long story) and wondered what difference the new valves would make in the valve clearances. When I saw the .01-.04mm, I wondered how I could be so far out. The .04mm was the smallest gauge I could find. I returned to this list and looked up valve adjustment threads and realized the numbers were scarily different, hence my looking elsewhere in the manual and this thread. Everything looks much better now, and I only need to change one shim.
                    Any idea what the numbers on page 56 could be referencing?
                    • ViperRon
                      • Feb 2011
                      • 1062
                      • Woodstock, VA
                      Some Clymer books were just printed wrong and there is also a torque spec for the rear wheel axle that is incorrect should be 108 ft lbs for the standard.
                      Rodan
                      1980 G Silverbird
                      1198 Overbore kit
                      Grizzly 660 ACCT
                      122.5 Main Jets
                      ACCT Mod
                      Mac 4-2 Flare Tips
                      Antivibe Bar ends
                      Rear trunk add-on
                        ......plus incorrect torgue specs on swing-arm, clutch basket retaining bolts........list goes on.
                        • LoHo
                          • Sep 2002
                          • 1342
                          • Fresno, CA
                          Is there a sticky page of the various issues? I have seen most of them over the years, but never noticed the cam specs until this time. Maybe a new thread...
                            • 5073
                            You are right. There should be a "sticky" for the corrections.
                              • 7830
                              LoHo, just go with the Yamaha specs from the correct book. If you need it, I can email some scans from the Yamaha manual to you so you always have them. PM me if you need it.
