I'll agree with Marty; tire sizes can be all over the map. You can go to the Dunlop site and find that even in the same size, the actual size can vary by tire model (sometime by nearly an inch!), not to mention any variations that may crop up in manufacturing. This is what makes fitting oversize tires such a crapshoot; tire 'A' fits in an oversize, you change brands or model and tire 'B' hits.
But assuming that the aspect ratio is accurate doesn't work either. I've seen tires the same measured width/nominal size but with nearly an inch different diameter too....
