Introduction; trying to work out the kinks
  • Scytale
    • Oct 2014
    • 23
    • Fort Collins, CO
    Hey,
    Name's Jon. Just brought my first motorcycle, a '79 XS1100SF. I'm excited for the upcoming adventures with it, and I look forward to being a part of what appears to be a great community. Before the adventures, I am trying to figure out some noticed issues, and was hoping for some information.
    First, the brake reservoir on the right side of the handlebar appears to have the remnant of some sort of sticker on it. The sticker is largely gone, and it feels wet under the remainder. (1) Is the wetness all right? and (2) What did the sticker look like, and is there some replacement?
    Second, I went into the garage later in the day after riding it, and saw a seal on the ground. The seal was by the kickstand, and is a hollow cone-shaped deal about 1/2" in diameter and 3/8" thick. Can anyone tell me from where the seal originated?
    Again, looking forward to the motorcycle and being a part of this community. Thanks for your help!
    ~ Jon
    '79 SF
    <'85 Ramcharger - matching set>
  • Scytale
    • Oct 2014
    • 23
    • Fort Collins, CO
    Sorry, moved the photos on Photobucket.
    '79 SF
      Hi scytale,
      The sticker is to tell you to use DOT3 brake fluid.
      I can not think of any reason for it to be wet.
      The rubber might be a piece of the stop for the stand? Have a look at the underside of the muffler to see if there is still a rubber ?
      • James England
        • 3039
        • North of England
        It's difficult to judge scale from the pic but I think the rubber plug might be a carb plug..a small rubber grommet that fits into the casting on the side of here carb. More decorative than anything else...
        From here?
        • mack
          • 2411
          • Ontario, Canada
          Plug
          It is difficult to tell but if you had the battery out, there are rubber gromets like that in the fuse box side of the battery box frame as well.
          If the top of the master cylinder is wet, the lid may have a crack in it. Investigate this as brake fluid is tough on your paint and keeping fluid in there for your front brakes could become an issue!
          mack
          79 XS 1100 SF Special
          HERMES
          original owner
          81 XS 1100 LH MNS
          SPICA
          78 XS 11E
          IOTA
          https://youtu.be/wB5Jfbp6SUc
          https://youtu.be/RaI3WYHSuWA
          Frankford, Ont, Canada
          613-398-6186
            Mike's XS has a new top for the master cylinder with the decal on it, but it's $70. Try searching Parts-N-More or Diablo Cycle for the sticker.
            • Scytale
              • Oct 2014
              • 23
              • Fort Collins, CO
              Those options sound like a promising place to start for both things.
              Thanks for the info, everyone!
              '79 SF
              • donebysunday
                • Oct 2012
                • 1737
                • New Berlin, Wi.
                Years ago I had as local print shop do up some labels for the switch gear and MC, the MC labels were a bit off, only a purist would notice, but there are some here, and should be. You have to cut them out with an xacto or sharp small razor knife, clean the surface to make them stick. If you like PM me.
                76 XS650 C ROADSTER
                80 XS650 G Special II
                https://ibb.co/album/icbGgF
                80 XS 1100 SG
                81 XS 1100LH/SH DARKHORSE
                https://tinyurl.com/k6nzvtw
                AKA; Don'e, UD, Unca Don'e
                • Bikes
                  • Oct 2014
                  • 174
                  • Coastal Maine
                  Welcome, Jon.....
                  Only a guess because mine are missing, the grommet/seal might be for the top studs on the side cover?
                  Mark
                  1980 xs1100g 3H5.......
                  1992 Ducati 907ie
                  2001 Moto Guzzi Jackal
                  • James England
                    • 3039
                    • North of England
                    The reservoir decal is readily available as new replica...here is one I bought...
                    • yamtom
                      • 275
                      • Midland Michigan
                      regarding dampness
                      There may be a couple of different causes of the dampness on that brake top. Indeed, it could be leaking from inside like someone said. Also, I believe brake fluid is made from an alcohol, alcohol attracts water, so maybe the condensation that may be present from temperature changes is made worse or apparently worse by the fact that the paper may be soaked with an alcohol product.
                      Bikes Now.
                      80 MNS 11 pods,georgefix kit,stock jets, HD Sporty muffs
                      79 XS 11 Special, Emgo pods, stock jets, with Pacifico fairing, hard bags, intact stock pipes Sold
                      83 Yammi Venture with custom footboards, 20k miles.
                      83 Yammi Venture parts bike
                      99 Valkyrie shield and bags 37k miles like new
                      08 ZX 14 Kawa Ninja 6k miles Sold
                      • mrhammer2u
                        • Aug 2014
                        • 472
                        • Northern, NJ
                        Funny,...I recently found the same piece of rubber in in my parts bin. I can't figure out what the heck it's for. Has anyone made a positive ID on it yet?
                        Rob - 79 SF
                          Maybe the battery breather had a plug instead of tubing and charging the battery popped it off?
                          • Eastcoaster
                            • Jan 2012
                            • 513
                            • oceancity NJ
                            Almost looks like the rubber grommet on the coil side of the spark plug wire?
                            But that would not be OEM?
                            82 XJ1100J
                            81 Venturer
                              • 2104
                              [/QUOTE]
                              IMHO that seal looks to be from a flexible water supply tube used to adapt your hard copper supply feeds, H & C, to faucets or toilet.
                              The indent, half way down, on the cicumference of the seal, is suspect to me.
                              Were you working on your house and bike at the same time?
                              If so, what the hell were you thinking
