Ive got the manual, Ive read the several posts, and the tech tip, yet after all these years I still have trouble feeling when the adjustment screw 'lightly seats' on the base. 1st I loosen the handle adjustment. Then I loosen the adjustment screw out to a point Im certain that its not touching, the whole assembly can wiggle side to side (the adjustment screw, nut and arm). Now, when I screw it back in, I will get to a point where I feel a light resistance, BUT, after I tighten the lock nut I can still grab the assembly and wobble it side to side. This doesnt feel right... so I tighten the screw more and the assembly begins to seat more firmly and tight, and I get to a point where the screw feels like it's bottomed out. I back off an 1/8 turn and tighten the locknut. I adjust the handle bar so I get about 5mm of play. I put the bike in 1st, pull the clutch handle, hit the start button, and it lurches forward...
I feel that if I back the screw out any more, the assembly will begin to wobble around again and that just doesnt feel right. Is that supposed to happen? BTW, my clutch cable is a new direct replacement from the yamaha dealership.
If the clutch isnt fully disengaging the friction plates from the steel plates, does that mean my adjustment screw is in too far or not far enough?
