opinions please
    • 8054
    Originally posted by mrhammer2u
    I'll be running my bike for a few minutes once a week just to keep the juices flowing. All the bike owners and landscapers I know use stabil in all their equipment though.
    Running for a few minutes will leave water in the crankcase and exhaust. I used my XS1100 all last winter to to go back and forth to work, 5 miles each way. It was not good for my bike. The oil looked milky from all the condensation. What you'll get from your few minutes running is bearing eating acid.
    • Roadman48
      • Apr 2012
      • 39
      • Central Ohio
      Don't really know why, but I use Sea Foam in the bikes built before 2000 and Stabil in the later model bikes. In either case I put in the additive, fill the tank run it until it is warm, shut off the petcocks and continue running until it stops. Been doing this for years with no springtime problems.
      FWIW Larry
      Larry
      1979 XS1100SF
      1981 XJ650 Maxim
      1981 XS650 (Frame off rebuild/mild custom)
      1981 SR500 (Pristine Stock Original)
      1979 XT500 (Configured as a TT500)
      2008 HD Sportster (With Texas Ranger sidecar)
      1967 Honda 305 Scrambler (Frame off restoration)
      1966 Honda S90 (Frame off restoration/My first bike)
      • Arthur_of_Hex
        • Oct 2014
        • 89
        • Bangor, ME.
        With all the tanks, petcocks, carbs and other fuel related areas we have to clean weekly on customer barn finds/rebuilds/behind the garage bikes they bring in, dry fuel systems are perpetually miserable to clean/restore to good running condition compared to wet. Last week did a rebel 250 that had been garaged wet without running for 10 years. The fuel had evaporated mostly leaving something the consistency of 2 stroke oil. Carb was smelly but cleaning gooey jets was way better than dry crusty powder-turned-solid jets. Granted one winter won't push the envelope but as stated above, any air leaves room for condensation. I store everything full after a good running dose of seafoam. My $0.02
        Matt
        81H Rebirth/Custom Build
        1st Gen RX7; Audi quattro; Wrangler JK
        PanikSwitch Cycles - Brewer ME
        http://s48.photobucket.com/user/Arth...201100%20Build
        • mack
          • 2411
          • Ontario, Canada
          #34
          Moth balling
          I've done it both ways. Just filled the tanks and drained the carbs. No problems on first start up. But this year I've drained the tanks and sloshed a cup of oil around in them, drained the carbs and pulled the batteries and put a tble spoon of oil in the cyclinders and exercised them.Replaced the oil and filter, then bleed and replentished the brake systems with new dot 3.This is what the Yamaha owners manual recommends when the length of storage is unknown. I hope to have the E up and running in the spring and will not be insuring either the 79 or 81 next year.
          mack
          79 XS 1100 SF Special
          HERMES
          original owner
          81 XS 1100 LH MNS
          SPICA
          78 XS 11E
          IOTA
          https://youtu.be/wB5Jfbp6SUc
          https://youtu.be/RaI3WYHSuWA
          Frankford, Ont, Canada
          613-398-6186
          • rdmcguy
            • Jul 2013
            • 515
            • Denver, Colo.
            #35
            trying again
            Am going to try to post video of my last Sunday ride.
            I fixed your link, you just need to post the URL from your browser when you are accessing/viewing the video, then our site will put the URL tags around it to
            make it active, you had extra Image and URL tags that messed it up. T.C.
            • scoot
              • Dec 2007
              • 153
              • Poway, CA: San Diego County
              #36
              Thanks for the video, that was fun. You can ride with me anytime.
              scoot
              • rdmcguy
                • Jul 2013
                • 515
                • Denver, Colo.
                #37
                Thanks TC.
                Thanks again fellas for your input..Thread started out about winterizing and morphed into why I was doing it so late in the season...Unseasonably warm last weekend ..................Moreso this weekend..82 today..ATTEMPTED another video today that made that road look almost straight ...Didn't work out..
                Maybe would be good for part of next years Colorado rally...
