Got a XJ. Its only a 550 but has YCIS like its big brothers so I figure the question is good here. Apparently, syncing carbs is hopeless without the block off tool. Got a nifty unit off of fleabay. Instructions say you can leave it in if I wanted to. What's the advantage/disadvantage to leaving the tool in? My first concern would be the O-rings burning up pretty quick. Since my 80G is "old school", I aint never had to frig with YCIS.
Why eliminate YCIS
Tags: None
I believe you will find the
answer you are looking for in this thread. http://www.xs11.com/forum/showthread.php?t=19708
the purpose of YICS was to eliminate emissions back in the day not to improve performance. I do not have a bike with that system employed, however the linked thread above states that folks do enjoy a performance gain by the permanent elimination of the system.2 - 80 LGs bought one new
Jim -
YICS was primarily an emission 'fix' and has very little impact on performance other than supposedly improving idle quality. If being 'clean' is something you want to do, then remove the tool after syncing the carbs. Otherwise, put it in and forget it...Fast, Cheap, Reliable... Pick any two
I installed one of Yahman's YICS eliminator and not only did it make carb syncing a hassle free task, it also improved both performance and idling. JMTCW1980G Standard, Restored
Kerker 4 - 1
850 Rear End Mod
Automatic CCT
1980GH Special, Restored
'82 XJ1100 (Sold)
Automatic CCT, RC Engineering 4 X 1 Exhaust, K&N Pods, #50 Pilot Jets, YICS Eliminator. Sorely missed.Comment
the purpose of YICS was to eliminate emissions back in the day not to improve performance. I do not have a bike with that system employed, however the linked thread above states that folks do enjoy a performance gain by the permanent elimination of the system.When a 10 isn't enough, get a 11. 80g HardbaggerComment
Maybe someone else will chime
in or maybe you already know. I would suspect that the tool that Yahman sells was specifically designed for the 11's. Is the carb bank the same/interchangeable on the 550's? Just curious as I have no experience with the 550. Thought others/lurkers might want to know definitively before making the mistake of going the Yics eliminator route and it not fit.2 - 80 LGs bought one new
JimComment
carb banks are not interchangeable between 550/650/750 to the 1100 engine. However the YICS tool is, it will work on all of them.Slow down and enjoy life. If you are in that much of a hurry, you should have left eariler.
Current rides:
80 XS1100SG
82 JX1100
83 Venture Royale
86 V-MaxComment
Ride safe,
LarryInventor of the YICS Eliminator. Want one? Get it here.
82 XJ1100
80 XS1100G (Project bike)
64 Yamaha YA-6
77 Suzuki TS-185
See it here... http://www.youtube.com/watch?v=cBYT4C9_6AcComment
Soon as I get my carb parts in, I will install the eliminator and let yall know how it works.When a 10 isn't enough, get a 11. 80g HardbaggerComment
I put one in my 550 and left it.
JohnJohn is in an anonymous city with an Alamo (N29.519227,W-98.678980)
'81 XS1100H - "Enterprise"
"Not all treasure is silver and gold"Comment
Got the "tool" from Fleabay. Cleaned out the YCIS passage (gun brush worked great). Installed tool. Hook up sync gauges. Had em all within a pound in about 15 minutes. Reved good, idled good. Didn't ride it yet cause the battery is toast and I didn't want to push it if I stalled it for some reason.When a 10 isn't enough, get a 11. 80g HardbaggerComment
Got the "tool" from Fleabay. Cleaned out the YCIS passage (gun brush worked great). Installed tool. Hook up sync gauges. Had em all within a pound in about 15 minutes. Reved good, idled good. Didn't ride it yet cause the battery is toast and I didn't want to push it if I stalled it for some reason.)
