HELLLP (Odd Clicking sound)
  • teck_mountain
    • Aug 2003
    • 128
    • Red Deer, Alberta, Canada
    1979 xs1100 special
    Just but it back together after replacing rings, pistons and etc. Had is running rough, would not ideal. Then it began to make a metalic CLICK, CLICK, sound every time the cams turned. I'm having a hard time isolating the sound. any ideas
    Teck (I really want to be riding not fixing)
    Tim Lowe
    "Teck"
    1979 xs1100 Special
  • ratbyk
    • 994
    • Sooke BC
    Tick Tick
    If you do not have a stethoscope you should buy one. The cut rate tool stores have them at very good prices. Short of that, take a long shaft screw driver, place the handle against your ear, move the the tip around holding it a various areas of the engine until you locate/isolate the noise.
    Ken/Sooke
    78E Ratbyk
    82 FT500 "lilRat"
    • MartyA
      • 2148
      • NW PA
      Turning by hand or idling? Could be the cam chain needs adjusting?
      You DID put oil in it?
      Marty in NW PA
      This IS my happy face.
      • DEmily
        • Jun 2003
        • 220
        • Kansas City, MO.
        Is it a clicking or a tapping. Is it happening when you simply turn it by hand?
        79 XS1100 f (BIGDOG)
        80 XS650 Special
        85 KAW 454 LTD
        Dirty Dan
          Re: HELLLP (Odd Clicking sound)
          You don't have a leak at one of your header gaskets, do you? That will make a ticking sound.
