clutch cable too tight?
    Also, what does "MP" stand for?
    Motion Pro, an aftermarket parts company. Used to be good, now suspect...
    You might try one of the parts sites, and see if they list the length of the cables someplace. Measure your cable, and then look for a shorter one. There ARE a VERY FEW shops left that know how to make cables. I used to all the time in the '70's, but have not for a while. HD and custom shops sometimes are able to build new cables in house, and to spec.
      • 4015
      And, charge a great deal for it too!
        • 2104
        Originally posted by GutSlasher
        I switched bars and now have 8-10 inches too much clutch cable. I know I could try playing around with the routing but since my cable is sticky as hell and I know it has not been lubed in over 5 years, I'm in the market for a new one. A parts guy at the Yamaha and my mechanic said avoid the universals, even if I reused the housing, the solder being untrustworthy.
        So I'm wondering if there is a cable from another Yamaha that fits the 1981 XS1100 Special but is shorter?
        You could have one made: http://www.barnettclutches.com/cables.html
        • donebysunday
          • Oct 2012
          • 1737
          • New Berlin, Wi.
          Ummm
          Originally posted by Schming
          Micheal Mercury Morse of vintage brake can not only supply you with great brake pads (shoes too) but cables made to your order or supply the parts for you to make your own custom cables, (clutch, throttle, choke) teflon lined.
          Tell him UD sent you, might not help but WTF ?
          76 XS650 C ROADSTER
          80 XS650 G Special II
          https://ibb.co/album/icbGgF
          80 XS 1100 SG
          81 XS 1100LH/SH DARKHORSE
          https://tinyurl.com/k6nzvtw
          AKA; Don'e, UD, Unca Don'e
          • GutSlasher
            • May 2009
            • 8
            • Vancouver, BC, Canada
            Thanks. I've requested a quote from Barnett. See what that costs...
              ..........or you could order an OEM cable from Yamaha, keep any lubing products away from it and its inner sheathing liner and it'll work smoother, longer.
                Motion Pro
                  Wait... Are you suggesting that we NOT lube the clutch cable?? Seems backward to me.
                    If a new replacement cable being used.......no lubing. The inner shieving of new cables, OEM or aftermarket is designed to 'wear slick' from cable itself.
                    If lubing is your choice, I'd use lube specificly for for that application. I had one of the older clutch cables off bike a few yrs. back, and lubed it while off with something other than regualr cable lube. Within an hour the inner shieving swelled up so tight cable no longer slid freely in housing. Haven't a clue how using other than cable lube would affect newer cable inner housings.
