help with right mirror, stripped out
  • mrhammer2u
    • Aug 2014
    • 472
    • Northern, NJ
    I stripped the hole out (long story short),....what's the best fix? They don't make this part anymore and I can't find on ebay at the moment. I'm thinking JB Weld,...but then getting it out could be a challenge if I even need to.
    Suggestions?
    Rob - 79 SF
    I've fixed one where the threads were all wallowed out by drilling and tap some 8-32 threads in the side of the MC and use 2 set screws to hold the mirror in place. It worked just fine....
    • mrhammer2u
      • Aug 2014
      • 472
      • Northern, NJ
      That's ingenuity!
      I found one on ebay for a 78 for $12. All I need is the metal piece, don;t care about the actul master cylinder. Think 78 and 79 are the same? Looks the same.
      Rob - 79 SF
        The mirror threads into the master cylinder, get another MC body.
        • Arthur_of_Hex
          • Oct 2014
          • 89
          • Bangor, ME.
          Suggestions?
          I have a replacement for mine coming from ebay land, when I confirm a good fit my current master will be available.
          Matt
          81H Rebirth/Custom Build
          1st Gen RX7; Audi quattro; Wrangler JK
          PanikSwitch Cycles - Brewer ME
          http://s48.photobucket.com/user/Arth...201100%20Build
          • mrhammer2u
            • Aug 2014
            • 472
            • Northern, NJ
            Thanks Arthur. I found one on ebay for $10 so I grabbed it.
            Rob - 79 SF
              Did you get one for a Special? It depends on which bars you are using.
              If you are using the original buck horn bars you'll need one for a Special, if you've gone to the flatter bars you'll need one for a Standard.
              The mounting angles are different.
