Just bought an 1100 F and it has NO low end grunt. At 3k it starts to wake up and at 3500 it is a rocket. Timeing is right, chain is tight. I am wondering if the carb. diaphrams fail.
Low end torque
1.Checked your timing with a timing light?
2.How are your vacuum hoses hooked up? The vacuum hose from the advance mech. goes to the nipple on carb #2, NOT the intake boot.
3. The centrifugal advance mechanism is prone to gumming up, I clean and lube mine once a year.
4. Back to #1 - all of these symptoms, if they are your gremlin, can be diagnosed with a timing light.
HTH
Randy -
Re: Low end torque
Some exhaust systems will do that to an engine. Also, bad exhaust systems can act that way (and errode the aluminum on the piston crowns).
Originally posted by dgreimel
Just bought an 1100 F and it has NO low end grunt. At 3k it starts to wake up and at 3500 it is a rocket. Timeing is right, chain is tight. I am wondering if the carb. diaphrams fail.Skids (Sid Hansen)
Don, you described mine very well. Mine will pull from 2,500 in any gear, but takes a long time to get to 3,500, then it takes NO time to get to 6,000 and up.
I have indy filters and 4-1 exhaust. This combo is supposed to move the torque / HP curve up in the RPM range.
After following Randy's good advice, consider the pilot circuit might be clogged. If the bike sat for any length of time your carbs could be in need of a cleaning. How does it start / idle?Marty in NW PA
This IS my happy face.Comment
me too
mine does that also.but it gets to that point rather quickly.its got very good throttle response.1982 XJ 1100
now in the stable. 1982 xj11, 18,000milesComment
Low end torque
Marty. I have had the bowls off and everything looks good although it did sit for several years. Much better than most of the old machines I have bought. It has KN filters and a new MAC exhaust and I did not that the main jets are quite large #155.
Have read the excellent info here on the site and plan to completely redo the carbs. I have them well synched and it starts and idles well.Comment
I had a similar problem with my E. In my case it was a bad pilot jet. Bike was running on 3 cylinders until carbs transitioned to main jets around 4200 RPM at which time it began running on all 4 cylinders.Pat Kelly
<p-lkelly@sbcglobal.net>
1978 XS1100E (The Force)
1980 XS1100LG (The Dark Side)
1999 Suburban (The Ship)
1994 Dodge Spirit (Son #1)
1968 F100 (Valentine)
"No one is totally useless. They can always be used as a bad example"Comment
