Many Problems
  • alaskey2
    • Apr 2014
    • 271
    • 60940
    Many Problems
    OK, at everyone's advice I took the carbs apart for cleaning. It did not go smoothly.
    1: The gas leaking down the side of carb 3 is from a T that had almost no rubber left.
    2: The right petcock leaks when switched to ON
    3: The carb boots are cracked though and need replacement
    4: Running grounds to battery did not stop it from stalling with the headlight on.
    5: I broke the tip of a mixture screw off in carb 4.
    6: I see no reason for carb 2 to be running as rich as it does.
    Well, I'm done ranting. I'm off to order new air mixture screws and pull my carbs to start struggling with this little tip stuck in there. Hopefully I can make it to the Distinguished Gentlemans Ride next Saturday sans headlight.
    78 E
  • alaskey2
    • Apr 2014
    • 271
    • 60940
    8: The choke does not stay at 1/2 or full. It just springs back to off. Any tips on what I did wrong putting that back together?
    78 E
      Missin' the detent ball, spring......or both.
      • alaskey2
        • Apr 2014
        • 271
        • 60940
        great, so that probably flew out to never be seen again. Where can I buy new mixture screws? Mikesxs.net and bikebandit dont seem to stock them? Seems odd to me.
        78 E
          • 4015
          Just curious if u followed the carb guide, or just went to town on them?
          • alaskey2
            • Apr 2014
            • 271
            • 60940
            I was supervised by a CB750 guy. And I had a repair manual.
            78 E
            • rdmcguy
              • Jul 2013
              • 515
              • Denver, Colo.
              the joy of carb work
              Been there myself with the misplaced spring and ball bearing...they are available at the Yamaha shop.....believe it or not 11 dollars apiece...I found a local spring distributer 18 cents... mixture screws also at Yamaha shop 12 dollars apiece... sounds like you also need to rebuild the petcocks
              Don't be discouraged btw if you decide to take the needles from the slides for cleaning... modified hemostats work well to remove the snap ring BUT BE AWARE THAT THERE IS A SPRING on the needle that will also fly into outer space if you are not careful....Guess how I know?
                Fix #1
                YAMAHA CARB TEE FITTING
                Mack did a video tutorial on tee repair. I'll let you look for it.
                Fix #2
                Rebuilding Yamaha Vacuum Operated Fuel Valves (Petcocks.)
                Fix #3
                YAMAHA XS1100 SPECIAL XJ1100 INTAKE CARB HOLDERS
                Fix #4
                Your bike may be riddled with corroded electrical connectors. Clean them up.
                • alaskey2
                  • Apr 2014
                  • 271
                  • 60940
                  Did the ACCT mod. Seems like my timing is off
                  Too... HALP
                  78 E
                    Idel Mixture Screw
                    I could send a used idle mixture screw if it helps (no charge).
                    PM me with an address if you need it.
                      You have that set on C it should by on T then check your alignment marks on the cams. C is where you set it to adjust the original CCT.
                      • alaskey2
                        • Apr 2014
                        • 271
                        • 60940
                        Cajun, thank you!!!! I was hoping that was the case.
                        78 E
                        • mack
                          • 2411
                          • Ontario, Canada
                          fuel t repair
                          mack
                          79 XS 1100 SF Special
                          HERMES
                          original owner
                          81 XS 1100 LH MNS
                          SPICA
                          78 XS 11E
                          IOTA
                          https://youtu.be/wB5Jfbp6SUc
                          https://youtu.be/RaI3WYHSuWA
                          Frankford, Ont, Canada
                          613-398-6186
                            Originally posted by rdmcguy
                            Been there myself with the misplaced spring and ball bearing...they are available at the Yamaha shop.....believe it or not 11 dollars apiece...I found a local spring distributer 18 cents... mixture screws also at Yamaha shop 12 dollars apiece... sounds like you also need to rebuild the petcocks...
                            I sell replacement choke detent spring/ball sets for $5 (postage included in the US), send me a PM...
                            Look here for where they go... http://www.xs11.com/forum/showthread.php?t=35964
                            • alaskey2
                              • Apr 2014
                              • 271
                              • 60940
                              Sent a PM about the screw and the choke sets.
                              Now, onto the electrical problem, I have ~12.5 volts standing, 13.7 at 3000+ rpm. Drawing about
                              10amps with lights on. Don't know if the amps are different when running since it can't start. Any tips besides redoing all the connections. That gonna happen tomorrow.
                              78 E
