I hate to be Captain Bring-down, but my Venturer has the worst suspension in the front end when comparing with my 2 different 78E's. Yes, I changed oil to Silkolene 15W. I don't use air in the forks and maybe that is a big part if the problem. I did notice that the H's springs seems to be progressively wound; however, that seems to mean that it is too soft for the initial compression. I bottom-out the front forks on bumps and I have no problem with that at all with my 78E's.
Changing Fork Oil
Forl Oil
The forks that I have had apart for seal replacement/cleaning were really dirty inside. I do believe that all of them had never been apart before.
I was surprised as to how dirty they were after only 30+ years.
Mike1981 XS1100H Venturer
K&N Air Filter
ACCT
Custom Paint by Deitz
Geezer Rectifier/Regulator
Stebel Nautilus Horn
EBC Front Rotors
Limie Accent Moves On In 2015
MikeComment
Thanks for all the feed back. The forks were completely rebuilt when Addie was resurrected by BDF and TinMan905 back in 2010.
Yes progressive wound springs were in spec then. New seals.
I do not experience bottoming out just very soft, Manual says to replace fork oil at 6000 miles. I have 25 -30,000 miles since then. Old oil was dirty.
My short ride felt about the same as before so no worse off.
Phil1981 XS1100 H Venturer ( Addie)
2004 Kawasaki Concours. ( Black Bear)Comment
If you add a little extra oil it will firm things up a bit, that, and/or add a couple of spacers next time you have them apart. Maybe your fork brace is defective.
☮Comment
Hi Phil,
Spacer idea sounds worth a try. Fork brace is doing just fine thank you
still has the same old nuts and bolts which I will "upgrade" some day
(Inside joke; I purchased my fork brace from Phil)
Seems complicated to change fork oil and replace seals. Called my local dealer and they're asking $270 labor (3 hours) plus materials! Think I'll do a bit more research and make this a winter project
Rob - 79 SFComment
they are not difficult
take your time and pay attention to what you are doing and all will go well. Cleaning them, replacing seals and fluids makes a big difference in the front end handling of the bike. Not miracles mind you but a noticeable difference.2 - 80 LGs bought one new
JimComment
MrH2-- Did mine last winter, was fairly straightforward. There's a thread on here somewhere about it. Mine came out and went in easy-peasy, got seals from ebay. I used ATF for the fluid, as it's recommended by old school mechanics, and I've used it in MX bikes, as well.79 F
1967 Suzuki X6 Hustler
1973 Suzuki TM 125
1979 XS1100 F
2005 Kaw. Vulcan VN800
1991 BMW K75Comment
