high heat paint
  • cmpnbd2
    • 42
    • shawnee,oklahoma
    high heat paint
    have 80 xs11 lg midnight special and want to paint/re-paint engine, exhaust, frame. what paint is good for this? will rustoleum high heat work and does it come in a glossy black?
  • tcoop
    • Nov 2009
    • 793
    • South Weber, UT
    I have used Duplicolor engine paint
    500* temp and it comes in gloss, satin and flat multiple colors too.
    Ty
    78 XS1100E - Now in Minnesota
    80 XS1100LG - The Punisher
    82 XJ1100 - Daughter's Bike
    • cmpnbd2
      • 42
      • shawnee,oklahoma
      paint
      did you use it on exhaust? rustoleum is 1200 degree
      • cmpnbd2
        • 42
        • shawnee,oklahoma
        exhaust painnt
        how hot does exhaust get to?
        • tcoop
          • Nov 2009
          • 793
          • South Weber, UT
          Just for the engine and frame. I have not had any luck painting the exhaust. Even the hi temp paints don't seem to last.
          Ty
          • CaptonZap
            • Jun 2010
            • 1748
            • Denver
            A properly tuned engine , at full throttle, will have 1250 +/- deg exhaust gas temperature, a few inches from the valve. Since you don't run at full throttle most of the time, 1000 to 1100 would be a good guess. As the gases go down the pipe, they cool off.
            Retarded timing, and/or a rich mixture will allow gases that are not done burning to exit the valve, and impart more heat into the head and pipe.
            Stock pipes are double walled, so discoloration is not a problem with them.
            The chrome plating process and chemistry also has an effect on how much or little the chrome on single walled pipes will change color.
            CZ
            • cmpnbd2
              • 42
              • shawnee,oklahoma
              paint
              seems that the rustoleum would be the one to use for exhaust , engine,trans,and duplicolor for anything with no heat involved
                For the exhaust you will need to use something like this.... http://www.cerakotehightemp.com/fini...glacier-black/ . This is a ceramic based paint and is rated for 2000 degrees.
                As for the frame and engine the High temp 1200 degree paints work well and you can get them in semi, gloss and flat as needed.
                I too own an 80LG and that is what I used for mine and it has held up well. I am looking at the cerakote product for redoing my exhaust system.
                  Pretty much any paint won't last on the exhaust. The MNS has what's called "black chrome" on the exhaust system. It's chrome but back just as it's name suggests.
                  Black ceramic coating would be your best choice there.
                  This is what I would suggest if you want to paint frame or body parts.
                  66 Auto Color is a certified House of Kolor distributor. We specialize in custom-mixed paints for automobiles, motorcycles, boats and more!
                  • TADracer
                    • 1417
                    • Kenner, Louisiana USA
                    For frame and body parts (tank, covers, etc.) use a good automotive paint if you want long life.
                    If you want to finish your exhaust pipes then preparation is the key and there simply are no shortcuts. Products from here - www.techlinecoatings.com/ - are great and you can mail order them. Have used them for years with no problems.
                    Mike Giroir
                    79 XS-1100 Special
                    • XJkid
                      • Jun 2003
                      • 281
                      • Elk Grove, Ca.
                      exhaust paint
                      I painted my exhaust with VHT ceramic rattle-can purchased at O'Reilly's. 5000 miles later it looks like the day I put it on. No primer, just scuffed up the chrome good, cleaned it off with acetone, and followed the directions. It's not glossy, but flat in a sparkly kind of way. I like it and it is easy to touch up rock chips and such.
