Need help with valve clearances
  • jrm000kc
    • Jun 2012
    • 66
    • Kansas City, Mo.
    I've been meaning to check my valve clearances for quite some time. I bought the motion pro hook tool last spring and still haven't used it. Every time I go out to do it, I chicken out. I now everyone says its pretty simple-but the margin for error is nil. I don't notice any unusual noise from the top end-but for peace of mind I'd really like to know that my clearances are good. If there's anyone in or around the KC area that could oversee me I'd greatly appreciate any help. I'll do all the work-I just need someone with experience to make sure I don't mess anything up. (The thought of taking a good running bike and bending valves is horrifying.)
    Anyhow thanks for reading and Go Chiefs! (They'll need a miracle today.)
    79 SF
    Raptor Auto CCT, octopus-less, tapped/plugged fuelcock prime ports, new shorter handlebars, original stock Yamaha seat (w/ Octo routing diagram), looking for stock grab-bar/sissybar/backrest.
  • mharrington
    • 407
    • Holland MI
    Checking the clearance does not require the MP tool- just the correct feeler gauges. The tool for an XS1100 to remove and replace shims will not be a hook shaped tool.
    • James England
      • 3039
      • North of England
      The Motion Pro tool is vaguely hook shaped. I found it useless but we've all had that debate before about its merits or lack of.....
      The XS1100 top end will get quieter as the valves wear into the seats. This means that the valve clearances get tighter. Check them all with a set of good quality feeler gauges and then report back with your findings.........
      If yo are not confident about this (you sound slightly not confident), I personally would be careful about using that tool.....
      • jrm000kc
        • Jun 2012
        • 66
        • Kansas City, Mo.
        It's not totally quiet-there's still the normal ticking and clicking of the valves. I'd rather not take it apart and find I need shims that I don't have-plus the gasket. I wished I'd checked them when I replaced the gasket last year...live and learn I guess.
        79 SF
        • LoHo
          • Sep 2002
          • 1342
          • Fresno, CA
          Yeah, checking them is no biggie. Take the cover off and rotate the engine, measure and record, and you might be done.
          You might want to keep and eye out for a parts bike that you can work on that you have less pressure about making mistakes. I cut my teeth on outboards that were beyond hope. The downside is you'll be very tempted to try to get the wrecks going again, a very slippery slope that will lead to dead and terminal bikes in your garage and yard.
          By the way, anyone in the market for an old outboard? It runs...sort of....
          • James England
            • 3039
            • North of England
            Originally posted by jrm000kc
            I'd rather not take it apart and find I need shims that I don't have-plus the gasket..
            You started this thread saying you want to check your valve clearances? Do you, or don't you? if you do indeed actually want to check them, then you need to take the cover off and check them. Very few people have bucket loads of shims, if any. You need to check the clearances and you may find they are all fine. If they are not all fine then you should change the shims and get the clearances right......
              ...And lots of people don't use a gasket on the valve cover, just some sort of liquid gasket. I've had the best luck from "The Right Stuff", but it is kind of pricier than some other options.
              If you find you need some shims, most bike shops that have been around any length of time will have some, or give a shout here if you can wait a few days for the snail mail swap. Take a micrometer with you though.. these bikes use a 29mm shim and there's some 29.5mm shims out there that won't work and you can't tell the difference with the naked eye even holding them together.
              • TADracer
                • May 2006
                • 1417
                • Kenner, Louisiana USA
                Just jump in and do it !
                If you own one of these fine machines and wish to keep it in good running condition without having to blow a wheelbarrow load of $ to dealerships who know less than you then, get your hands dirty. There are very few things on an XS that are hard to do. First, get your self a manual if you do not have one.
                Having said that, it is not hard to pull the valve cover and you can use a liquid gasket maker to re-install it. I personally like Yamabond from the dealership but then, that is just me.
                Rotate the motor with the timing plate (left side cover) until the cam lobe is away from the bucket and use some metric feeler gauges (unless you feel like converting to American Standard) Intakes should measure .16 to .20 mm and Exhaust should be between .21 & .24 mm. If you are out of range then you will need to change a shim and do a bit of math (refer to your manual).
                Seriously it is not hard and you should check it periodically as it is part of the normal tune-up procedure.
                Mike Giroir
                79 XS-1100 Special
                • James England
                  • 3039
                  • North of England
                  Often, if you're lucky, you'll find that the camcover gasket is useable after you take the cover off. Careful use of a snap knife or scalpel blade can make the gasket come away with the cover. Even if torn, it can be reused with silicone gasket compound. Or, as has been mentioned, only gasket compound can be used...
                  • jrm000kc
                    • Jun 2012
                    • 66
                    • Kansas City, Mo.
                    Yes, I do...
                    Of course I want to check them. If anything I probably go overkill on maintenance and servicing. To ease your mind I plan on checking them tomorrow and referencing my gaps with my manual.
                    I'd love to find a salvage bike except I live in an apartment complex so having a bike in pieces probably wouldn't bode well with the landlord. (Plus all the sticky fingers around here.)
                    My bike is my honey and I just want to be sure about everything before I turn a single bolt.
                    79 SF
                    • jrm000kc
                      • Jun 2012
                      • 66
                      • Kansas City, Mo.
                      Valve clearance measurements
                      Finally got them checked yesterday. Here's what I measured:
                      Exhaust: .008, .008, .008, .007
                      Intake: .006, .005, .006, .006
                      Pretty decent except for the last exhaust valve. I wasn't that concerned so I put it back together because winter is coming on and I don't ride that often during. Definitely be a spring project.
                      Okay so has anyone posted a metric/inches conversion table for shims?
                      79 SF
                      • Prisoner6
                        • Aug 2013
                        • 1184
                        • Phoenix, AZ
                        Hi, James -
                        Well, the specs for your '79 SF are as follows:
                        Intake - .006-.008 in. which equals .1524-.2032 mm
                        Exhaust - .008-.010 in. which equals .2032-.254 mm
                        As you can see, you have 1 intake and 1 exhaust clearance that are out of spec ... and all the others are at the very low end of spec.
                        I think the consensus here is that most like their clearances on these 11's at the high end of spec, because as has been mentioned ...
                        The valve clearances get tighter over time, which makes the top end quieter.
                        Adjusting them to the high end of spec makes for a noisier top end, but IMO gives you peace of mind.
                        Marco
                        1979 Honda CBX
                        2002 Kawasaki ZRX1200R
                        WE MISS YOU, DON
                        • James England
                          • 3039
                          • North of England
                          Charts
                            I'll add that if you delete the cam cover gasket and just use some sealer, you might get some contact between the cover and some of the nuts holding the cam bearing caps on. I've ran into this twice (so it's not a sure thing) but both times contact was 'light', just enough to mar the inside of the cover. Some light grinding will open it up easily...
                            • jrm000kc
                              • Jun 2012
                              • 66
                              • Kansas City, Mo.
                              Thanks a bunch for the charts Mr. England!
                              I was able to salvage the gasket-but I added Yamabond when I put it back together. I'm sure there will be no salvaging the gasket next time though...I'm in a parking lot and the idea of leaving my bike disassembled just didn't sound good...definitely buying a 5mm allen ratchet head for those 20 freaking bolts next time. I'd still prefer someone there that's done it before to make sure I don't do any fatal mistakes. I'll buy them a case of beer.
                              79 SF
