dropped washer in engine should I worry?
  • mrbsyammy
    • Jul 2006
    • 119
    • Racine Wi.
    SOB I don't believe what I just did..*&^^%%$#$ taking cams out to put new head gasket on my xs1100 and sure as the sun rises in the east I dropped one of those tiny washer that sits under the cam nut right by the opening muther chicken cotton picking dirty rat etc etc. So is this something I should worry about considering its tiny or should I worry about because it is tiny??? SOB (*^%$#@#%&)(*&^%$#@#^*..
    Till then Mr.Bill
    79 XS1100 SPECIAL (2) 1100 wings- 82 HONDA CX 500 TURBO (2)77 GOLDWING 86 HONDA NIGHT HAWK 84 HONDA 700 83 nighthawk 650 SC-INTERCEPTOR 2 1975 RUPP CENTAURS VW TRIKE (2) 77 YAMAHA 750 TRIPLE 84 YAMAHA 600 83 GS 750 SUZUKI 70? CB350 Honda scrambler- THATS ALL THIS WEEK MR.BILL
    • 9981
    Drop the oil pan. It will most likely be in there.
    • mrbsyammy
      • Jul 2006
      • 119
      • Racine Wi.
      I didn't want to hear that! Well I do have a gasket for it so I guess its not all that bad! but Iam still P Oed..All the ones I could have dropped it had to be that one SOB!!! Does that just drop or do I have to take other crap off? I wish I had it on my rack but theres been a wing on there for a LOOOONNNGGG time..
      Thanks Till then..
      P.S. my man Brad #2 won his 4 th race in NASCAR and dominated the race he will start in First on the chase race GO BRAD!!
      • mrbsyammy
        • Jul 2006
        • 119
        • Racine Wi.
        Thanks Till then..
        The night ended well Brad won and I found the washer when I took the head off it was laying on the floor so it must have been between the fins? don't know don't care I found it yeah!!!
        Till then Mr.Bill
        • mrbsyammy
          • Jul 2006
          • 119
          • Racine Wi.
          how to check warpage on tops of jugs?
          XS1100 how to check flatness (non warped) on the tops of cylinders were the head goes on with all the studs?
          Till them Mr.Bill
            Well,
            Without an actual machinist's RULE, you could get a metal yard/meter stick, and use the EDGE to lay across the cylinders in different positions, across, perpendicular and oblique/diagonal avoiding the studs, and see if you can put a feeler gauge between the ruler's SIDE edge and the head??
            If you have a large glass covered picture, painting or such, as long as the ruler, you can use it's surface to check the trueness of the metal yard sticks' EDGE beforehand. Glass is fairly stiff and usually quite flat....if it's a fairly large picture, I would leave it standing upright, the glass could flex a little when layed flat at that size!? JAT!
              • 9981
              Cylinder warpage is a very, very uncommon problem
              • James England
                • 3039
                • North of England
                It's usually only the alloy heads that warp, not the cylinders.
                • mrbsyammy
                  • Jul 2006
                  • 119
                  • Racine Wi.
                  The head is great so the heck with the jugs..lol
                  Thanks Till then
                  • TomB
                    • Aug 2006
                    • 967
                    • Cumbria, UK
                    Well,
                    I found something way flatter than glass, the preformed rolled edge kitchen counter tops are very flat if not screwed down distorting them, I ran a DTI in big arcs over ours at home (whilst the wife was out) it was 0.0015" out, yes 1 and 1/2 thou, you could easily check a head on it using feeler gauges, it would be accurate enough.
                    Tom
                    • mrbsyammy
                      • Jul 2006
                      • 119
                      • Racine Wi.
                      its as flat as? no I'm not going there..lol lol..used my thinnest feeler gauge and a 6 in metal ruler and it is perfect lucked out on this one..
                      Till then n thanks
