cam chain
  • mrbsyammy
    • 119
    • Racine Wi.
    cam chain
    Since I have to replace my head gasket AGAIN what is the life of stock cam chain? on 79 xs1100
    Till then
    79 XS1100 SPECIAL (2) 1100 wings- 82 HONDA CX 500 TURBO (2)77 GOLDWING 86 HONDA NIGHT HAWK 84 HONDA 700 83 nighthawk 650 SC-INTERCEPTOR 2 1975 RUPP CENTAURS VW TRIKE (2) 77 YAMAHA 750 TRIPLE 84 YAMAHA 600 83 GS 750 SUZUKI 70? CB350 Honda scrambler- THATS ALL THIS WEEK MR.BILL
    • 7817
    Till then
    Cam chain life is determined by how much you beat up on it. Stock tensioner? How far extended is it? The chain isn't too expensive or tough to replace. If I had any uncertainties, I believe I'd get a new one.
    • red bandit
      • 951
      • central michigan
      I've got 65,000 on mine and see no need to change it. YMMV.
      79 F full cruiser, stainless brake lines, spade fuses, Accel coils, modded air box w/larger velocity stacks, 750 FD.
      79 SF parts bike.
        Hey Mr. Bill,
        As stated, depends on how well the bike was maintained or beaten upon. The indicating factor is with the OEM cam chain tensioner, it has a certain amount of travel to take up the slack that occurs as the chain stretches from age/wear. When the tensioner is fully extended while in place, then the chain has worn/stretched far enough to require replacing.
        The chain can be changed WITHOUT splitting the cases. We highly suggest installing a different type of cam chain tensioner vs. the OEM due to it's propensity to wear out/ loose it's tension allowing the plunger to move and too much chain slack to occur, which leads to the chain hopping cam sprocket or crank sprocket teeth, putting the valves out of time, which leads to pistons meeting valves=bent valves or worse!
        Either install the ACCT, or perform the mod to the OEM with the carriage bolt, a search should reveal the threads complete with photos and info on how to make the MOD yourself, and thoughts/pros/cons for both types!
          • 1881
          To follow up on TCs comment
          • mrbsyammy
            • 119
            • Racine Wi.
            Hey Mr. Bill,
            I should have mentioned the bike has 20,000 original miles and adult driven which I find to be a stupid statement an adult could beat the crap out of it. I am 66 yo and believe me I'm old but far from dead, I am so crippled up I can barley walk but I still enjoy speed and love it when some young puppy is going by me and finds out how fast an XS1100 is and I usually will get a thumbs up when they ketch up to me at next stop sign.. All kidding a side I am a perfectionist and take very good care of my bikes which is about 14 or so. The factor tensioner looked good and wasn't at the end of its travel so I should be good to go! and what is a ACCT? I do thank all that replied to my question. Have a great day.
            Till then and thanks again. Mr.Bill
              • 7817
              ACCT= Automatic Cam Chain Tensioner
              There is much about them in this forum. It amounts to replacing the tensioner with a maintenance free unit from a later machine.
              • mrbsyammy
                • 119
                • Racine Wi.
                ACCT explanation wow I just lost what I just wrote wt? I can never find anything on search for whatever reason?
                Thanks Mr.Bill
                  Thanks Mr.Bill
                  Well V-Max/Venture has been the first choice for 'plug'n'play' over the years.
                  Several Yammy applications work.....Raptor,Vision, ect.........there's 40+ options on a list here somewhere.
                  Has been proven the stock one with the mickey'mouse pinch bolt will NOT hold in place upon a hard decel, and HAS to be re-set...again..and again. The loose timing chain also changes cam timing.
                  Self tensioning one keeps cams in time ALL the time.......and they don't 'weep' oil.
                  • mrbsyammy
                    • 119
                    • Racine Wi.
                    I agree on auto n can't afford anything over $1000
                      Well then, you could get you a ACCT and have it gold-plated.
                      • mrbsyammy
                        • 119
                        • Racine Wi.
                        talking about a motorcycle dah..lol opps
                          • 1881
                          Mr. B
                          Go back to my post #5 in this thread and click on the links I provided. Your question on ACCT will be more then answered and the thread from crazy steve will actually give you choices of which ACCT you might want to pick up off of Ebay. Your $1000 statement has led me to believe you might be confused by moto's last post.
                          • mrbsyammy
                            • 119
                            • Racine Wi.
                            you think?? oxicontins tend to mess with my head I hate them but if I don't take them I am stuck in my recliner . I bought a new head gasket and Yamaha is not cheap. So should I put a small amount of sealer around the cam chain area since I am not reusing the gasket that some have never seen and is no longer made that was used on some but not others?
                            Till then Thanks Mr.Bill
                            • mrbsyammy
                              • 119
                              • Racine Wi.
                              Hey Mr. Bill,
                              The manual ones don't excite me in the least I don't like the idea of metal on metal at all! was on ebay and didn't find any ACCT aftermarket tensioners? all I could find was manual and stock?
                              Till then Thank you Mr.Bill oh P.S. have new head gasket and I am not reusing the extra gasket that doesn't exist, so should I use a sealer around the cam chain opening?
