I think I killed Hugo.
  • GLoweVA
    • Jun 2011
    • 1957
    • Virginia Beach, VA.
    Since Monday, I've been riding him to/from work to see how'd he do.
    Well, today was a bad day.
    I'd been dealing with some lean conditions and thought it might be a fuel level problem and was going to tear into them this weekend.
    Basically, I have no top end acceleration. I could cruise about 75 (5k rpm) but couldn't hardly accelerate much after that.
    Getting up to speed seemed a little slow, but did okay. (not as good as Scarlet, she screams thru the gears)
    Okay, Hugo has the oil cooler and lowers on the fairing.
    Today traffic on the Slab was very slow and I've been dealing with some sticky brakes, so it was hard to keep him going stop and go. I think he over heated a bit. Also I was running low on fuel (trying to see what the mileage would be)
    My theory is he was so hot, the fuel was 'boiling' in the carbs and kinda starving for fuel and it would even keep up at 45. I pulled over and put 1/2 gal in the tank from my can and cycled open the bleeders on the front brakes to see if that would free them up. Got back on and he ran okay for about 20 mins. at 75mph, then started sputtering bogging down again, I slowed and pulled over and stopped. let him idle for a second or two and he went fine til I home about 15mins. later.
    One of the things I'm going to make sure I have the 4H0 TCI, just in case. I'll probably check the vac. advance to make sure it's rotating okay too.
    Definitely pulling the carbs and totally going thru them. (they are the SG carbs and have the pilot crossover)
    I'm also going to rebuild the front master cylinder and clean out the calipers too.
    I think I was averaging about 45mpg
    Last Sunday I had the plugs out and they were ghostly white.
    Looks like I'm back on Scarlet for the commute. (got to order a rear tire for her soon, XS SE is right around the corner....)
    80G (Green paint(PO idea))
    The Green Monster
    Got him in '04.
    bald tire & borrowing parts
    Scarlet
    Got her in '11
    Ready for the twisties!
    81H (previously CPMaynard's)
    Hugo
    Cold weather ride
    Wow!........is all I can say. That would be a close one for a piston/cyl. seizure! BTDT.....with power pulling down, and not from a normal load on it either. Likely didn't notice it, but I bet those header pipes were 'pinging' too under the slightest load. Noticing that would of been the leat if your concerns at that point. Think you may have 'dodged the bullet' this go round. With some minor cyl. 'scuffing' likely won't be as fortunate second time . Hopefully no collapsed piston skirts, but you'll soon know once you get the carbs squared away. Hope it all works out!
      • 9980
      Sounds kinda like you may have some leaky diaphragms George and the heat may have added to the issue. When you get those carbs apart check those diaphragms really good, especially out near the edges. That's usually where the holes show up.
        • 8054
        Hopefully, Hugo is going to be OK. How white is white? The porcelain is supposed to be white. It's bad it you got flecks of melted aluminum on there. Hopefully, you're good.
          George,
          You've got to stop trying to see how LEAN you can run! Mileage is one thing, but holing pistons is another...and you've BTDT!!
          I thought you preferred Scarlet/SG for the twisties anyways?? And aren't you trucking/hauling it down there instead of actually RIDING it?? I'm trailering Godzilla as usual, have to visit MOM in Ala., and this time helping her get packed up to MOVE down to just north of Orlando, but I won't be moving her, my cousin is coming up to get her and take her and her stuff down there!
          I haven't heard from John(Oldbiker##) in Richmond...the parts guy, that's why I haven't followed up regarding a parts run up there.
          Okay, hope you get it worked out and don't have any serious piston damage.
          I experienced a slight overheat condition several weeks ago on a weekend trip to my work place, started getting smoke vapors from the leaked oil on the head...but was able to finally get moving and got it cooled down.
          • GLoweVA
            • Jun 2011
            • 1957
            Yeah greg , i was also thinking about the diaphragms too. I just forgot to mention that in the post.
            Marty, they weren't porcelain white. More like ashy white/grey.
            TC, i was toying with the idea of riding Hugo to SE, but he needs to much to get him twisty ready. Scarlet hardly needs much.
            The Green Monster
            Got him in '04.
            Scarlet
            Got her in '11
            Hugo
            Cold weather ride
              • 9980
              I've been in that position many times on trips. If the cylinders are to hot to touch you gotta get some air flow.
              The shoulder of the highway is king.
                Doesn't leaking diaphragms lets the needles drop, blocking the air flow and creates a very rich scenario where your plugs would be very black?
                My thinking was just a plugged tank vent or a kinked line?
                  • 8054
                  I don't think you killed him. I had mine so lean, the electrodes were white.
                    Good point trbig......specially for those following the back and forth bantor on the carb thread.
                      • 9980
                      It would drop the air flow to an extent but the jet needles wouldn't be raising fully out (not all the way but to max flow) of the needle jets allowing full fuel flow.
                      Could be a fuel tank cap vent plugging up too.
                      • GLoweVA
                        • Jun 2011
                        • 1957
                        No kinks in the lines and i had opened the cap, so not the vent. I also put them on prime too and that didn't help either.
                        I'll update this thread this weekend as i tear into it.
                        Thanks for all the input.
                        Oh and thanks for the "different" views on the anatomy of the carbs thread.
                        The Green Monster
                        Got him in '04.
                        Scarlet
                        Got her in '11
                        Hugo
                        Cold weather ride
                          Oh.......then your gonna really like it when I get back to Bizarro land from GA. ......stay tuned .
                            • 9980
                            Must be an electrical problem.
                            Or, running lean because the float levels are too high. Air too explosive?
                            • rdmcguy
                              • Jul 2013
                              • 515
                              • Denver, Colo.
                              count me out
                              I;m staying out of this one!!!!!
