? about jetting
  • mrhammer2u
    • Aug 2014
    • 472
    • Northern, NJ
    ? about jetting
    Hi all, noob here. Thanks for the add! Bought and XS11 couple weeks back and tearing down a but to customize. I'm replacing the stock 4-2 exhaust with the Mac 4-2 turnout exhaust. I went to a Dealer the other day and he scared the bejeezus out of me when I asked him about pricing for tuning and told him about this exhaust mod. He made it sound like the worst thing I could do and would probably be 5 hours of billed labor ($95/hr!) to test and tune to get jets right. And that everytime the temp changes, I'll be back.
    My question is,.....the Mac and stock exhaust are both 4-2 baffle systems. How much different can they really be? I live in NJ where temps go from 50-90 from spring to fall.
    Thanks and look forward to getting to know you guys!
    Rob - 79 SF
    • 7765
    There are a lot of people here who would kill for a stock exhaust!
    The MAC should work OK and you tune it yourself. We're here for you.
      Ask those that run them.....BA80 comes to mind, and IIRC.......no change needed to.
      BTW.......a 'dealer' doesn't automaticly make them 'smart'...........99.9percent of time it's exactly the opposite.......old OR new modern bikes.........but don't get me started on that subject........trust me, they're clueless cept what salesman tell them that walk thru the door.......and U already know what that's worth ...
      • mrhammer2u
        • Aug 2014
        • 472
        • Northern, NJ
        Thanks guys. I just got off phone with Mac's tech guys. He said since I'm going from a 4-2 baffle to 4-2 baffle it should be fine. He had the same sentiment when I brought up the "dealership guy". Pipes should be on by weekend. Will let ya'll know.
        Rob - 79 SF
          • 9980
          I have the Mack turnout system on my SG. I like it. It does however run slightly leaner than the stock system since it is more free flowing.
          I upped jet sizes by 1 size on both the pilot and the main jets a couple years ago and it helped quite a bit. I think I could have gone 1 more size up on both because it's still just a tick lean.
          I have the same carbs you do. I like the older style because of the adjustability they allow. Much more than the newer 80 - 81 or XJ carbs allow.
          • TADracer
            • May 2006
            • 1417
            • Kenner, Louisiana USA
            Read between the lines
            What the dealer is telling you is that he does not want to deal with it, because you have a 30+ year old machine, not that it cant be easily done.
            Plenty of tuning tips to be had on this site but if you are switching out a 4-2 for a 4-2 you are probably OK with stock jetting.
            Mike Giroir
            79 XS-1100 Special
            • mack
              • 2411
              • Ontario, Canada
              stock exhaust
              why are changing them. Whats the condition of the stock system. Don't let the installer keep them. Bring them home with you and offer them to the membership.
              mack
              79 XS 1100 SF Special
              HERMES
              original owner
              81 XS 1100 LH MNS
              SPICA
              78 XS 11E
              IOTA
              https://youtu.be/wB5Jfbp6SUc
              https://youtu.be/RaI3WYHSuWA
              Frankford, Ont, Canada
              613-398-6186
                BA80, what you might consider since your bike uses the early carbs, and you regularly ride LD with higher speed 'slab' cruising is put one of the teeny- tiny washers that's used on the later carbs mixture screws between the 0ring and spring. Put it under the metering rod clip. That will richen up the main circuit just a tad at cruisin' speeds . That's equivalent to half a step richer in the main circuit, and would be the 'tick up' your lookin .
                If needed, when I get back to biz......er Colo., can get you the Suzuki part #. Those ARE still available thru mother Suzy, but NA from mother Yammy .
                • WMarshy
                  • Apr 2009
                  • 2402
                  • Mexico NY
                  Maybe he should lower the bowl level to richen it up then he wouldnt have to buy the washers. lol
                  '79 XS11 F
                  Stock except K&N
                  '79 XS11 SF
                  Stock, no title.
                  '84 Chevy K-10 "Big Blue"
                    Just suggesting a legitimate, already proven solution Wade........from Ken Talbot almost a decade ago.
                    Maybe a l-o-n-g ride would suppress the suspect animosity .
                    Meanwhile.........carry on my fellow XSer .
                    • mrhammer2u
                      • Aug 2014
                      • 472
                      • Northern, NJ
                      Hi Mack. I'm the installer. And just want a better looking system. Love the turnout style. Once I know they work good I will offer of the stockers which are in great shape.
                      Rob - 79 SF
                        • 9980
                        On these carbs I have 5 settings on the jet needles just like a Dynojet kit for the newer ones but the older carbs came stock that way. No need for cobbling.
                        I'm running the needles on the middle groove. I have 2 more settings to raise them.
                        BTW, the springs on the needles on these early carbs are opposite the needle springs on the later ones so that would lean me out even more.
                          Aware of the five slots, just have seen some reported instances here over the years where one step raisin' the needles was a bit more than needed. Anyway, was just a suggestion for the ' tick more richer' .
