turn signal problem on a 79 sf
  • rneal55555
    • Aug 2003
    • 210
    • Milton, NH
    Had the same problem with my XS 650 had a worn of bare spot on the hot wire to the rear light it was shorting to the frame. Little bit of electrical tape and it works.
    Russ Neal
    Milton, NH
    04 GL1800 ABS
    04 Kawasaki Concours(Sold)
    99 Royal Star Venture(Sold)
    80 XS1000 Special(Sold)
    83 XJ750 Midnight Maxim(Sold)
    80 XS1100G(Sold)
    81 XS 650 Special(Sold)
      Now that I have my flashers running, I need to figure out the hazard lights. I have not tested it but I suspect the switch or wires running to switch because I know flasher is good and looking at the wiring Scematics, there is not much left.
      -Jonathan
      Hey there Jonathan,
      The Emergency Flasher circuit is a separate circuit in that the power is run thru a separate Flasher unit, so if you replaced your turn signals unit only, there is another flasher, under the seat near the battery IIRC!? Happy hunting!
      • thumperjsa
        • Apr 2004
        • 547
        • Coconut Creek, Florida
        I verified that the hazard flasher was good by swapping it with the one I used for the signals. Both worked for flasher so it must be in the hazard circuit.
        Right now, this is the least of the issues I have. I discovered a low compression issue which I posted details in another topic.
        Owned by a pair of XS11's. An 80 Standard and a 79 Special.
