signal switch
  • dpotter58
    • Aug 2004
    • 1865
    • Southern Maryland
    signal switch
    The wire for my right turn signal came loose so I pulled it apart and soldered it back in place. Now, both signals work but the right will only work if I first push the switch towards the left then the right.
    What did I do? I'm thinking I bent one of those copper arms in there. Sound right? if so, witch one and which way do I need to bend it back?
    1980 LG
    1981 LH
  • dpotter58
    • Aug 2004
    • 1865
    • Southern Maryland
    I know one of you brain surgeons has the answer to this....
    1980 LG
    1981 LH
    • donebysunday
      • Oct 2012
      • 1737
      • New Berlin, Wi.
      No brain surgeon here, don't even play one on TV ! I would guess, bend them inward to where they are about the same. What I don't get is why you can push the opposite way you want, then push the way you want and then it works the way you want ? ? ? Easy enough to test it before putting it back together.
      76 XS650 C ROADSTER
      80 XS650 G Special II
      https://ibb.co/album/icbGgF
      80 XS 1100 SG
      81 XS 1100LH/SH DARKHORSE
      https://tinyurl.com/k6nzvtw
      AKA; Don'e, UD, Unca Don'e
      • dpotter58
        • Aug 2004
        • 1865
        • Southern Maryland
        Done, they both look the same now. I'm out of town and was looking for ideas for when I get home.
        Glad to see you back up and posting!
        1980 LG
        1981 LH
        • Cobia
          • Jul 2007
          • 1587
          • Palm Beach County, Fl
          Mine does the same and I blame it on corrosion. After I do it a few times it works properly until the next time it sits for a few days. I live in an area with a lot of salt air and have no garage, only a carport.
          1980G Standard, Restored
          Kerker 4 - 1
          850 Rear End Mod
          Automatic CCT
          1980GH Special, Restored
          '82 XJ1100 (Sold)
          • donebysunday
            • Oct 2012
            • 1737
            • New Berlin, Wi.
            I would try cleaning with a pen/pencil eraser, then check, if working dielectric grease them. Pen eraser is more abrasive.
            Thanks ! Good to be back, now working on pulling a wrench
            76 XS650 C ROADSTER
            80 XS 1100 SG
            • dpotter58
              • Aug 2004
              • 1865
              • Southern Maryland
              I cleaned everything when it was apart using de-oxit. It wasn't a problem before. I also changed the rear light assemblies with new units. New wire from the plus on the fender back. Cleaned the whole wire trail with de-oxit and a small round wire brush for all the connectors before I found the broken wire. I'll just pull it apart when I get back home.
              1980 LG
              1981 LH
              • Brent
                • 959
                fix is in your sights
                Good for you Duane!
                "Found the broken wire" Now fix is esy.
                Brent in GA
