no air filters??
  • XJOK2PLAY
    • 2099
    • Skiatook, Ok.
    Originally posted by motoman
    Does it act up when turning RIGHT.......or just straight ahead?.
    Sounds like the carbs are having................never mind......not even goin' there.
    LMAOROTF!!!
    Geesh....ya make one little geographical miscalculation....
    And ya never live it down.
    Too funny.
    2011 Kaw Concours 14 ABS
    • WMarshy
      • Apr 2009
      • 2402
      • Mexico NY
      Originally posted by rdmcguy
      Thanks fellas,
      ...stock jetting across the board floats at 26.5...
      That could be the cause of your problems, float height set wrong.
      '79 XS11 F
      Stock except K&N
      '79 XS11 SF
      Stock, no title.
      '84 Chevy K-10 "Big Blue"
        +1........even half a millimeter makes a heck of a lot of difference of actual fuel levels. From my own experimenting, 1mm of static float level change equals right close to 3mm of actual fuel level change in bowls.
        • rdmcguy
          • Jul 2013
          • 515
          • Denver, Colo.
          don't know don't care
          After fighting with these carbs for an eternity I believe I FINALLY solved the problem......After shuffling multiple carb sets I reached the conclusion that I needed to drop the needle (raise the clip) on the slide needle two positions
          I don't know why this set of carbs required that .....the only thing I can think is that the jbm industries replacement dictated it.....
          As I said don't know don't care.....end of story......I hope
            • 3373
            I didn't know you had adjustable needles, missed that part. For sure that is going to be a key way to tune out your richness.
            2001 ZRX 1200
            1982 Seca 750
            1983 Nighthawk 550
