Ok I have a very clean XS1100 special with 20,000 original miles on it the head gasket was leaking so I replaced it and since I had it apart I relapped the valves and put the correct shims in and since then it hasn't quit ran right. Its been stumbling on idol and stumbling at 3,000 rpm besides for that it runs out very strong. I put my temp gauge on the after market 4 into 1 headers and the pipes were hitting mid 650 degrees which I thought was a bit lean so I pull the tops of carbs which was a dirty rotten SOB since the Phillips screw were beyond tight had the use hammer and chisel on 3 of them and of course the worse ones were the ones you couldn't get at straight because of the frame and as long as I was at it I 86ed the octy that%$#@*&%& thing what dumb ass came up with that nightmare should be shot! And I replaced all the Phillips with S/S Allen head bolts so I would never have that problem again. Anyway I put one washer on the needle to raise it and it seem to start and idol a little better with choke one but the rest didn't change much still stumbles at 3,000 rpms and it still doesn't idol that great? Temp on it now is upper 500 degrees so whats next? new plugs filters like new oil n filter new so whats next? ran great before I took it apart and still balls out runs great it just at 3,000 rpm n idol? still too lean? And no the idol circuit isn't dirty.
Till then Mr.Bill
Till then Mr.Bill
