'81 Hard to start when hot
  • stereomind
    • 109
    • Tulsa, OK
    Hey folks. I've only had my Eleven for a couple of days, and have already added almost 300 miles to the odometer. She runs like a pig with a rocket strapped to it!
    I noticed that after a long ride, the bike is sometimes hard to start if I let it sit for a few minutes. If I kill it and re-start it immediately, it's fine. If I let it cool off a bit, it's also fine..
    So it's just when it sits hot for a while. I can get it to restart pretty quickly if I crank it over with the throttle wide open. Idle is perfect, regardless of temperature.
    It's not that big of a deal, and my XJ650 does it too, but I figure there's probably something that could be done to improve this behavior.
    Any ideas? Thanks in advance!
    '81 XS1100SH "Hound of Basketville" - new project
    '81 XS1100H Venturer
    '81 XJ750RH Seca
    This happens to most carbureted bikes. In the heat the fuel vaporizes after sitting a bit the air box fills with vapors and acts as if it is flooded.
    I have eliminated the octy on mine and now sometimes if I forget to shut off the fuel it will flood a little.
    Best thing I've found to do is if either of these things occurs is to hold the throttle wide open when cranking and it clears out and starts up pretty quick.
    • stereomind
      • 109
      • Tulsa, OK
      So it's just nature of the beast... Thank you for the explanation.
      This makes me wonder though.. My XJ750 almost never does it, and the only difference on it is a slightly um.. unrestricted airbox (I cut the inlet open to about twice its original size), with a K&N filter. So maybe the vapors vent quicker because of that, minimizing the problem?
      peace
      Vlad
      '81 XJ750RH Seca
        Bob had the hard starting issue a couple of years ago on his XJ1100 during a ride in the summer heat. I assume that the 750 has an airbox similar to the 1100.
        Maybe the extra ventilation does help.
        • ViperRon
          • Feb 2011
          • 1062
          • Woodstock, VA
          You might try checking the gasket and pressure relief on the gas tank cap it can cause issues like this if bike pressurizes from heat but most times causes bike to act like its running out of gas at high speed.
          Rodan
          1980 G Silverbird
          1198 Overbore kit
          Grizzly 660 ACCT
          Barnett Clutch Springs
          R1 Clutch Fiber Plates
          122.5 Main Jets
          ACCT Mod
          Mac 4-2 Flare Tips
          Antivibe Bar ends
          Rear trunk add-on
          • tinman905
            • Aug 2007
            • 946
            • Orangeville,Ontario ,Canada
            Had the same problem with my 80 SG I replaced the carb float valve (needles & seats) and the problem went away. My bike can sit in the sun all day long and it will start right away even when I forget to shut the petcocks off.
            BDF Special
              105 - 110 degrees Fahrenheit ambient?
                This factory float level settings we use doesn't help matters. Mine did the same from new, and it IS kinda the 'nature of the beast'. But' I've found playing around with actual FUEL levels for some time now, that a tad lower fuel level in bowl resolves that...tottaly.
                  It may resolve that problem but will create another, lean condition on WOT.
                  Choose the lesser of 2 evils. Vote.
                    Yeppers.......can be compensated SOME with idle mixture settings, but main circuit ends up a bit 'hungry'........definitely a 'catch 22'.
                      Well,
                      Mine hasn't had any problems starting hot or cold. I do have POD filters.
                      Sounds like we may have found a valid reason to have Pods vs. the Oem Airbox that gets flooded with evaporated gas fumes!? However, perhaps if folks would drill a few holes on the bottom of the OEM airbox in the center section may help reduce the saturation of the evaporating fuel fumes?
                      • ViperRon
                        • Feb 2011
                        • 1062
                        • Woodstock, VA
                        My bike came with an air box with a hole in the center bottom but you need to clean and or replace the filter from time to time. I use the white AC filter material cut off a thin strip and role it to fit in.
                        Rodan
                        1980 G Silverbird
                        1198 Overbore kit
                        Grizzly 660 ACCT
                        122.5 Main Jets
                        ACCT Mod
                        Mac 4-2 Flare Tips
                        Antivibe Bar ends
                        Rear trunk add-on
                          Well,
                          There again TC, trading one issue for another.
                          The cooler the air that you can get to the intake the more power the engine can produce. Drawing air from just above the crank case and behind the cylinders is perhaps hottest air around the engine. That's one of the reasons the air box snorkel goes up and back under the seat.
                          With pods there is more airflow but when your going down the street or highway feel down there around those pods and see how hot the air is.
                          That's a drain hole Ron. So any liquids that might get in there for any reason will have a place to drain off.
                          • stereomind
                            • 109
                            • Tulsa, OK
                            I have a feeling she's running a bit rich.. I can smell it. Also, my mileage sucks.
                            I think the carbs are gonna have to come off this weekend. Perhaps the richness is making the problem worse.
                            '81 XJ750RH Seca
                              That it will, if the pilot circuit is restricted.
