R6 Caliper Brackets
    • 3918
    R6 Caliper Brackets
    I'm interested in following "TheRev"'s mod and putting R6 calipers and updated rotors on my bike for better stopping power. Obviously buying the rotors and caliper are simple, but I have no fab experience. I'd be interested in getting a pattern I can take to a shop for the caliper brackets. Would any other calipers work better over an R6 caliper?
  • Yahman
    • Mar 2008
    • 779
    • Salem, OR
    Here you go, I did this one for Geezer a couple of years ago.
    Ride safe,
    Larry
    82 XJ1100
    80 XS1100G (Project bike)
    64 Yamaha YA-6
    77 Suzuki TS-185
      • 3918
      Wow, thanks Larry! I guess I can start planning this.
      • WMarshy
        • Apr 2009
        • 2402
        • Mexico NY
        Keep in mind that his template is for blue R1 calipers and not R6. I don't know if they differ from each other but I thought I would point it out.
        '79 XS11 F
        Stock except K&N
        '79 XS11 SF
        Stock, no title.
        '84 Chevy K-10 "Big Blue"
          • 3918
          I was looking at Ebay between the R6 & R1, they looked similar.
          • Yahman
            • Mar 2008
            • 779
            • Salem, OR
            I don't know if there is any difference between them, the part numbers are similar. The drawing gives a starting point though. I have some R1 calipers, but I have not tried to install them on anything.
            The drawing was made when a pair of adapter brackets that Tony purchased didn't fit right, so he took the measurements to fix the problem and make new ones. I documented all of that for him with the drawing.
            Larry
            82 XJ1100
            64 Yamaha YA-6
            77 Suzuki TS-185
            • WMarshy
              • Apr 2009
              • 2402
              • Mexico NY
              I assume 310 mm rotor diameter... might not make much of a difference but some years has 298 mm rotors and thickness varried as well.
              '79 XS11 F
              Stock except K&N
              '79 XS11 SF
              Stock, no title.
              • Yahman
                • Mar 2008
                • 779
                • Salem, OR
                I went to the dealer and measured them at the time but I don't recall what they were.
                Larry
                82 XJ1100
                64 Yamaha YA-6
                77 Suzuki TS-185
                  • 3918
                  "TheRev" has told me that the rotors should be 325mm. I found some for an FJR, and another for a Ducati Multistrada.
                  • Mathh
                    • Nov 2006
                    • 676
                    • Beek, Netherlands
                    325 is not correct. Depending on the year it varies: 298mm and 320mm.
                    MV Agusta Brutale 910R '06.
                    Yamaha MT-09 Tracer '15 grey.
                      • 3918
                      I might have mis-spoke. 320 sounds right.
                        • 7862
                        I have some loose XS1100 and XS650 rotors. I have three loose ones and all are 298 mm in diameter. I believe the XS1100 rotors to be from a standard. They don't have slots and the calipers I got with them are for a standard.
