Up and Running
  • Murrayf
    • Jul 2014
    • 41
    • Lexington , N.C.
    Up and Running
    out of a basement abandoned in 1994
    now with new (everything lol) but running like a champ
    to all of you that i have gotten parts off of so far thanks so much
    well off to weld up some exhaust i blew the rust and some holes out
    of what was left of the stock system on the dyno the other day
    and to install my new back shocks
    79 SF
  • James England
    • 3039
    • North of England
    Well done! You saved another one. You must be feeling pleased....
    All you need to do now is restore the car that's in use top left of the bottom pic
    • Murrayf
      • Jul 2014
      • 41
      • Lexington , N.C.
      that is a trike body
      79 SF
      • Murrayf
        • Jul 2014
        • 41
        • Lexington , N.C.
        well some cutting tig welding hanger making and drilling
        a trip over to the box of harley take off muflers
        and a no leak exhaust system one more thing off the list
        79 SF
          Hey Murray,
          Don't stop there. Tell us about the carb and intake mods you've done. Are those flatside carbs....or just direct cable pull type slides, not CV/vac. actuated. And are there 4 carbs or only 2?
            Those look
            like Mikuni VM round slide carbs. That has to be some custom manifold setup though.
            • Murrayf
              • Jul 2014
              • 41
              • Lexington , N.C.
              they are modded vm38
              i will finish playing with these then go to a set of tmx flt slides with accel pumps
              once i have a complete baseline and have finished drive ability
              this is just a modification of my honda cb900 carb kit
              79 SF
              • Murrayf
                • Jul 2014
                • 41
                • Lexington , N.C.
                here is my 1982 cb900c with flat slides kit
                and the smaller version that is for the cb750 dohc
                79 SF
                • Murrayf
                  • Jul 2014
                  • 41
                  • Lexington , N.C.
                  ok a quick update lol
                  i was just out on the road for the first time almost have it where i want it
                  the thing hauls i need a bit more ignition work but otherwise its good
                  front brakes still suck lol even with teh fork brace i feel
                  like its cloudy with a chance of a front end swap
                  the progressives i put on the back are good no more jacking around on
                  a hard twist of the throttle
                  the new shinkos 230s hang on great and feel good!
                  i have to go thru the new tail light wiring as the lamp indicator is not happy
                  and its not a oil pressure issue
                  i have to finish tig welding the new rear frame section and then decide
                  what i am doing about side covers as then i can get them and the tank and
                  seat pan vinyl wrapped to match my other demo bikes
                  79 SF
