2nd Gear Fix is Eminent, Denial is Futile
  • WMarshy
    • Apr 2009
    • 2402
    • Mexico NY
    Started developing the dreaded 2nd gear issue last season and noticed 4th gear is doing it on hard pulls also. Back cutting the dogs seems eminent at this point but I only have one machine to ride. I'm likely going to pick up a spare set to work on while I baby the rest of this season. I have access to a vertical mill and plan to "do it right".
    Right now Im doing some reasearch on recommended back cut angle. So far 3-5* backcut seems to be common. Anyone care to guess how thick the case hardening is on these dogs? I might stick with 3 degrees for the sake of not removing any more material than I have to...
    When I get to it I will post learnings and pics.
    '79 XS11 F
    Stock except K&N
    '79 XS11 SF
    Stock, no title.
    '84 Chevy K-10 "Big Blue"
  • rover
    • Jan 2004
    • 765
    • central WI (715)
    gears
    3* should be enough to hold the dogs/slots together. I don't think you will be able to cut the slots with an end mill. Even then, you would need special end mills with the sides cut at the 3* angle. Stones are about the only thing that will cut the case hardened parts, but stones wear rather quickly.
    79 F (Blueballs)
    79 SF (Redbutt)
    81 LH (organ donor)
    76 CB 750 (gone to MC heaven)
    rover has spoken
    • WMarshy
      • Apr 2009
      • 2402
      • Mexico NY
      Carbide endmill will work just fine. A rotary table would be the cats @ss and help speed up the work, not sure if I will have access to that though...
      '79 XS11 F
      Stock except K&N
      '79 XS11 SF
      Stock, no title.
      • jwhughes3
        • 2798
        • Home of the Alamo
        I dont think you can grind and not go thru the hardened section.
        John
        '81 XS1100H - "Enterprise"
        • WMarshy
          • Apr 2009
          • 2402
          • Mexico NY
          John
          At this point all reasearch suggests that any material removal will likely result in the removal of the case hardened boundary layer. Im not exactly sure which method was used to case harden it, or what steel the gear is (my guess is a low carbon) but thickness varries based on those two parameters. It could be as thick as a few tenths of a thousandth or as much as ten thousandths of an inch. Process makes a big difference...
          How would you attribute metal, properties that would assure external hardness as well as internal toughness to it? Low carbon case hardening steel is made through one such process through which a metal’s outer crust is made very hard and tamper proof without disturbing its internal compositions. Case hardening of low carbon steel material is quite popular and is widely employed and finds varied applications in numerous fields. The article explains many different case hardening procedures like open-hearth, box, cyaniding, nitriding etc.
          '79 XS11 F
          Stock except K&N
          '79 XS11 SF
          Stock, no title.
          • WMarshy
            • Apr 2009
            • 2402
            • Mexico NY
            Anyone looking for a lite read?
            Seems like a good database of info...
            Trusted by the world’s industry leaders to deliver sustainable, innovative products and solutions to the planet
            '79 XS11 F
            Stock except K&N
            '79 XS11 SF
            Stock, no title.
