Tire bead breaking technique
  • rdmcguy
    • Jul 2013
    • 515
    • Denver, Colo.
    Thought I would pass on a somewhat primitive yet effective way to break the bead on a stubborn tire....Get a soft towel or whatever to place under your rim CAREFULLY put it just behind (or in front)of your car tire, back slowly and CAREFULLY up on to JUST THE TIRE ,...as you drive onto the bike tire ...the rim will lift slightly from the ground..on the side that is not captured,put your cage in park...step on the bike tire and voila the bead is broken sometimes it takes more than one attempt..I have used this technique a hundred times and have never caused any damage and it ALWAYS works.....
    • 5069
    I like that idea!
      Lol.......you'd have to know Joe to appreciate some of the stuff he comes up with................El Toro comes to mind.
      • Orange4
        • Sep 2013
        • 398
        • Maple Ridge, B.C., Canada
        You could also take your excavator and push down on the tire carefully with the bucket. Don't forget your towel.
        If you don't have an excavator, there is usually one in your neighborhood fixing streets that I'm sure no one would mind you using... just for a minute.
        Living to EXcess.
        1979 XS1100F Canadian, stock exhaust. Top end rebuild in progress.
          And each brand only uses one key, and some keys cross brands even......
          • rover
            • Jan 2004
            • 765
            • central WI (715)
            bead
            I used to put a brick on the ground under the bumper of the car or some other heavy object, set the rim/tire on the brick, just clearing the rim, put the pad on a bumper jack on the top, again just clearing the rim, and use the jack to break the bead. Now I just use my manual tire changer from Harbor Freight.
            79 F (Blueballs)
            79 SF (Redbutt)
            81 LH (organ donor)
            76 CB 750 (gone to MC heaven)
            rover has spoken
              In the tire change pictorial is shown using a basic large C-clamp to slowly squeeze the bead to break it. Anything is better than doing the "RAIN DANCE" with your feet!
                Hi Rover,
                Can you post a picture or link of what you have ?
                Thanks Phil
                • scratcher09
                  • Dec 2013
                  • 19
                  • San Antonio, Tex.
                  I use a similar method. I lay the wheel down. Then I use a piece of 3/4" plywood (16"x24" works fine) and lay it over a section of tire making sure it is not covering the wheel. Then I carefully drive my car up on top of the plywood and it easily breaks the bead. This method is quick and has never failed.
                  80 LG
                  • red bandit
                    • 957
                    • central michigan
                    I stick it in my vise and crank the handle.
                    79 SF parts bike.
                      • 9980
                      I use the tire machine at work.........
                        Hi red,
                        What size vice do you have? I have a lot of vices......but only one made of metal and a 4" jaw
                          Hi red,
                          One of the reasons I love my vise! Snagged it out of my grandma's house as she was moving out. It was a beefy old thing 6" wide jaws and it opens about 8-10"
                          • red bandit
                            • 957
                            • central michigan
                            Phil, jaws about 6" wide & opens about 8". It's a china cheapy that someone bought for me about 20 years ago. I've used the crap out of it.
                            79 SF parts bike.
                              I let someone else use the tire machine.
