Master cylinder? pics reuse or new kit?
  • jkluczyk
    • Apr 2014
    • 28
    • Mount Prospect, IL.
    So i have a project bike, the master cylinder was all gunked up. I'm looking to spend the least amount of money on this bike. The brakes didn't do anything. I took apart the master cylinder cause no fluid was coming out at the top. Does it look like I can clean this up and reuse? or do i need a new kit?
    81 XS11
    1984 Honda VF700s
    1974 Yamaha RD350
    • 8077
    If it were me, I'd put a kit in it. There is the time vs. money to consider. You may have success doing a thorough cleaning, but if not, you do the job again. Also, it's brakes. They are priority #1 in my book.
    • jkluczyk
      • Apr 2014
      • 28
      also, anyone know where i can get the brass washers cheap for the break lines?
      81 XS11
      1984 Honda VF700s
      1974 Yamaha RD350
      • DeanR
        • Jan 2005
        • 1499
        • Finger Lakes NY
        I got a big box of copper washers at Harbor Freight for cheap.
        80 SG
        81 SH in parts
        99 ST1100
        91 ST1100
        • jkluczyk
          • Apr 2014
          • 28
          score, got a hf right by my work.
          81 XS11
          1984 Honda VF700s
          1974 Yamaha RD350
          • jkluczyk
            • Apr 2014
            • 28
            Bit the bullet, order new master cylinder rebuild and caliper rebuild too.
            81 XS11
            1984 Honda VF700s
            1974 Yamaha RD350
              • 2007
              Good call
              Brakes are nothing to play around with, especially on these bikes. You will never regret doing the job right the first time. Make sure the pistons are not pitted. If they are I would also look into replacing those with SS. A good site for those is HVC. Might want to do a search on caliper rebuilds. Quite an entertaining read but also full of good ideas. Good brakes help with mpg to. Of course YMMV.
              • jkluczyk
                • Apr 2014
                • 28
                I've done brakes a couple times now. Unfortunately, can't really see the pistons cause i couldn't get them out because the master cyl wasn't pushing fluid down. I will inspect those when the time comes. And i use the K&L catalog and usually find the best price by just using the part number on ebay.
                81 XS11
                1984 Honda VF700s
                1974 Yamaha RD350
                  • 2007
                  something I put in my toolbox
                  I bought a set of these to have in my toolbox. http://www.tooltopia.com/otc-tools-4...FcZQ7AodylwAng
                  Very good at removing stuck pistons. They clamp much like a set of vice grips on the ID of the caliper then all you have to do is just strike down on a board slow but sure and the caliper will come out.
