My MNS
    • 1812
    My MNS
    A few photos of my restoration
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    and I don't want to leave out my night train
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
  • ViperRon
    • Feb 2011
    • 1062
    • Woodstock, VA
    Looks good but you did not have to put that Harley next to it to make it look better though.
    Rodan
    1980 G Silverbird
    1198 Overbore kit
    Grizzly 660 ACCT
    Barnett Clutch Springs
    R1 Clutch Fiber Plates
    122.5 Main Jets
    ACCT Mod
    Mac 4-2 Flare Tips
    Antivibe Bar ends
    Rear trunk add-on
      • 6753
      Beautiful job on that resto...that is awesome...I need to meet you...shake your hand and buy you a few rounds...
      With all the "hey everybody I'm gonna chop my XS11 up...what do you think?" threads running around it is really refreshing to see a truly well done restoration...
      1980 XS650G Special-Two
      1993 Honda ST1100
        • 9980
        +1 on both posts.....
          +3!...........even like the styling of the NightTrains.
            • 1812
            always been of the opinion
            that a motorcycle can be any color you want as long as it's black.
            Both bikes are in great shape and both run very well. Thanks for the comments the restoration was a joy and the culmination of several years of collecting parts. I have a full set of original pipes that are going back on the bike, just trying to decide on what to redo them with. They are physically solid with the typical black chrome pitting for their age but I plan on glass bead blasting them and probably will go with the new glacier black cerakote ceramic paint. It is supposed to withstand temps up to 2000 degrees. we shall see.
            • MarkD
              • Jun 2013
              • 488
              • N. Michigan
              Beautiful bikes, especially that MNS.
              79 F
              1967 Suzuki X6 Hustler
              1973 Suzuki TM 125
              1979 XS1100 F
              2005 Kaw. Vulcan VN800
              1991 BMW K75
              • donebysunday
                • Oct 2012
                • 1737
                • New Berlin, Wi.
                Very interested in that 2000° paint !
                Beautiful bikes !
                76 XS650 C ROADSTER
                80 XS650 G Special II
                https://ibb.co/album/icbGgF
                80 XS 1100 SG
                81 XS 1100LH/SH DARKHORSE
                https://tinyurl.com/k6nzvtw
                AKA; Don'e, UD, Unca Don'e
                  • 1812
                  so much for glass bead blasting
                  Blast the parts with 80 to 100 grit aluminum oxide or garnet sand at 80 to 100 psi. Strive for an even blast pattern over the surfaces of the parts. Do not use glass beads, as they dimple the surface rather than etching it, which is required.
                  • mack
                    • 2411
                    • Ontario, Canada
                    Mns
                    Beautiful work. Now all you need is some dry shine spray wax to keep it clean. Easy to use. Spray on and wipe off. Has an anti static quality that helps keep the dust to a minimum.
                    mack
                    79 XS 1100 SF Special
                    HERMES
                    original owner
                    81 XS 1100 LH MNS
                    SPICA
                    78 XS 11E
                    IOTA
                    https://youtu.be/wB5Jfbp6SUc
                    https://youtu.be/RaI3WYHSuWA
                    Frankford, Ont, Canada
                    613-398-6186
                      • 7786
                      I don't remember ever seeing a Midnight at the Southeast rally. I wish you could bring that one! It's pretty!
                        • 1952
                        Cajun:
                        It's a treat to see your project in it's glory.
                        Great job, and thanks for showing it off.
                          • 1812
                          thanks
                          for the kind words. The bike has always been a joy to own and I am just pleased to bring it back to it's glory. I plan to keep it and the only way it goes to a new owner is when my daughters sell it when I am gone, which I hope is a long time from now. I plan to keep it looking good and running until then and I will tell my daughters about this site. Not done yet though. I still have the pipes to do. For some reason the ceramic paint I was going to use on them is not available at the moment.
                          Mack, I am also looking into your post on what you used on your spica project, however you stated you used Thermo Chrome from techline. Was that cerma chrome black you used? I have been looking a Cerakote Glacier Black C-7600 as an option because the product is supposed to be able to be air cured for 12 hours rather then oven cured. Still looking a searching though.
                            • 1812
                            called Cerakote today
                            the product I was looking for was temporarily unavailable but they told me that it would probably be back in stock by next week. Cost is reasonable but the prep work for painting pipes is a bit involved. Think this is what I am going to try though.
                            • donebysunday
                              • Oct 2012
                              • 1737
                              • New Berlin, Wi.
                              I put a MAC 4-2 tapper muff set on my LH, now the set I had on it with the stock standard head pipes and dunstall reps. will be painted with Duplicolor 1300-2000° flat black and over that the same but clear. I think you can see the flat on the left and then cleared over on the rt.
                              Guess it will be and experiment and I will need to blast the entire set including the muffs. $8.99 per can, now to find a blaster and the media you suggested, $ ?
                              76 XS650 C ROADSTER
                              80 XS 1100 SG
