While we are on the subject of gears... Strange shifting
    'Gap-rod' to the rescue...........in the future, if the 'dogs' jump the slots in first or second gear, that'll likely happen again........which will then lead you to the 'gear fix'.
    • Orange4
      • Sep 2013
      • 398
      • Maple Ridge, B.C., Canada
      Off topic, I want to remove the aluminum cover adjacent to the starter cover to polish it. What is behind there? A bearing? Can I remove it without opening up a can of worms?
      BTW, when the dogs pop out do you end up in neutral or a lower gear? Also, who let them out?
      Living to EXcess.
      1979 XS1100F Canadian, stock exhaust. Top end rebuild in progress.
        • 7942
        It will remain in the 2nd gear position. Instead of forward motion, you'll get a lot of noise as the edges of the dogs and slots are beaten into a round shape that will ensure they never engage. It will feel like a very noisy neutral.
        • Orange4
          • Sep 2013
          • 398
          #34
          Ok. good. That has never happened under my watch. I think my 2nd gear is OK. The PO said he had second gear fixed years ago by Yamaha (insert craigslist seller disclaimer here). Although I do get clutch slippage under WOT at about 6500 rpm so I won't know for sure until I fix that and take it for a boot.
          On the topic of craigslist sellers, the guy who sold me the '79 told me it had a new set of rings and it actually turned out to be true when I took apart the top end. Craigslist miracle?
          Living to EXcess.
          • mack
            • 2411
            • Ontario, Canada
            #35
            Cover
            I didn't notice anyone answer your question about the the other half of the starter cover. You are correct in assuming there is a bearing under it. The bearing is fixed to the cover and will pull off with a little persuassion. There are two thin oil seal rings which make it a little tight to slide out. The end of that shaft the bearing fits on is the primary that the hyvo drives and immediatly inside the case(on that side) are the conical springs that take up the snatch when shifting into first. It's all cool to remove it and buff it up, nothing will fall out or drop down.
            mack
            79 XS 1100 SF Special
            HERMES
            original owner
            81 XS 1100 LH MNS
            SPICA
            78 XS 11E
            IOTA
            https://youtu.be/wB5Jfbp6SUc
            https://youtu.be/RaI3WYHSuWA
            Frankford, Ont, Canada
            613-398-6186
            • donebysunday
              • Oct 2012
              • 1737
              • New Berlin, Wi.
              #36
              I was going to mention before but got sidetracked.
              This is for anyone that knows and can answer. Pertaining to the condition of his star washer, something caused this, should it be investigated before riding for what really was the cause ?
              76 XS650 C ROADSTER
              80 XS650 G Special II
              https://ibb.co/album/icbGgF
              80 XS 1100 SG
              81 XS 1100LH/SH DARKHORSE
              https://tinyurl.com/k6nzvtw
              AKA; Don'e, UD, Unca Don'e
              • Orange4
                • Sep 2013
                • 398
                #37
                Thanks for the info on the starter cover's neighbor. It's as good as polished.
                I'm guessing the star washer was bent when it mis-shifted but whaddoiknow?
                Also, no one informed me as to the situation regarding the dogs and the identity of the person or persons who allowed them to become loose.
                Living to EXcess.
                  .....post #31.
                  • Orange4
                    • Sep 2013
                    • 398
                    #39
                    So are these designed to pop out to save the gears? Hence the whimpy retaining tabs?
                    Living to EXcess.
                      I think some reading is in your near future. That tab U 'fixed' has nuttin' to do with popping out of gear......that's the result.
                      ALOT of unwanted motion from pieces that are SUPPOSED to be LATERALLY stationary goes on to cause that......initially all started from improper shifing technique clutch adjustment AT clutch incorrect, 'speed' shifing or all of the above, whichever so slightly rounds off corners of gear engagement 'dogs'.
                      • anarchy18
                        • Sep 2011
                        • 134
                        • Germany
                        #41
                        Why did he tackweld the tip of the washer back on are they that hard to find or expensive? Well here begins the perilous journey of translating the part names like shiftfork into German and trying to find one here I put in tranny and xs1100 in German Ebay and everythings for the 2H7 and 2H9 models will those fit in my 5K7?
                        '81 Yamama XS1100 5K7 German Model
                        What's the difference between erotic and kinky?
                        Erotic = using a feather
                        Kinky = using the whole chicken
                        • Orange4
                          • Sep 2013
                          • 398
                          #42
                          I fixed it so I could go riding instead of waiting for a new part to arrive.
                          I don't know if the transmissions are identical. I would think they are but I'm not an expert here. James England probably knows.
                          Living to EXcess.
                          • Orange4
                            • Sep 2013
                            • 398
                            #43
                            Update. It now shifts much better after adjusting the eccentric as per the instructions. Especially better shifting down into first gear. It still gets stuck while downshifting between third second but much more rarely.
                            Thanks!
                            Living to EXcess.
                              #44
                              Hey folks,
                              My question is why was the shift drum assembly built that way with varying length pins necessitating that funky washer? The pins all bottom out at the other end of the shift drum, why weren't they all set to the same length, so that a simple stronger flat washer could be used to secure them in place?? IF mine ever bends/breaks, I'll probably just grind down the pins level and put a big flat washer there!
                              This will have to do for now. That's a 308L 1/16" filler rod welded to the washer. I also did a bunch of little jobs that have been nagging at me like properly mounting the spaghetti pipes. Next job is to replace a few exhaust studs that have been bodged by the PO.
                              • anarchy18
                                • Sep 2011
                                • 134
                                • Germany
                                #45
                                Heck Ya TC GOOD IDEA!!! Think I can do that with mine if my funky washer (and that really is a awkward dang washer) is bent or broke and pins fell out? What if there are no pins in my oil pan where do I get some new ones so I have my 5th gear back!!!
