While we are on the subject of gears... Strange shifting
  • Orange4
    • Sep 2013
    • 398
    • Maple Ridge, B.C., Canada
    Hey guys,
    I'm getting some strange shifting behaviour almost always while shifting down.
    When I'm shifting down some times the lever stays down. When I then shift up, it goes into 2nd instead of neutral.
    Sometimes it will not shift into first right away and I have to mess with it.
    Sometimes it will only shift into neutral until I shift up and down again. Seems to shift down better while moving above 10 mph.
    Once it seemed to end up between gears and made some grinding noises. That time I stopped and shifted down until it went into first. It has always returned to normal after messing with it a bit. (knock wood)
    It started after I did two things:
    #1. I changed the oil to a semi-synthetic M/C wet clutch 20-40W approved Lucas oil from whatever the PO had in there.
    The strange shifting didn't start untill after I did #2
    #2. I lowered the shift lever one spline which made it hit the header pipes at the end of it's travel. Only noticed after It stated shifting weird. Don't know how much it retarded the travel yet.
    I returned the lever to it's original position but It still shifts weird sometimes.
    It did pop out of second a few times but only recently and randomly. Don't know if it's related to the strange shifting or if I need the dremel fix.
    Any ideas?
    Living to EXcess.
    1979 XS1100F Canadian, stock exhaust. Top end rebuild in progress.
    Originally posted by Orange4
    Hey guys,
    Shift pawl likely out of adjustment.....put in second gear, remove shift cover(
    Any ideas?
    Likely shift pawl out of adjustment....remove shifter and cover after engaging to SECOND gear. Alignment marks align....if not, adjusting is done at the cam eccentric at shift shaft, lock but and adjustment screw.
    • Orange4
      • Sep 2013
      • 398
      Ok. Thanks. I'll get into that and have a look.
      Living to EXcess.
        • 8937
        There is a centering spring inside the cover on the shift lever shaft, might be broken? JAT
          That too......if lever has no 'return' tension on it.
            Or weak. Had a weak one on my SF I had to change
            • Orange4
              • Sep 2013
              • 398
              Does not seem like the spring. It just gets stuck down and pops to level once I lever it up with my foot. Not a lot of force needed.
              I'll get it open tonight after work.
              Living to EXcess.
                It's the spring. Easy fix.
                  Exactly BA80's point.
                    Hey Orange,
                    You may already be working on it, but from your description it IS the spring, they get sprung like all other springs. When that happens it will NOT push the shift lever back UP to the normal position which resets the pawl to grab the next gear. The spring is only like $10-15, order/get one and replace it while you're in there! You'll probably find that the alignment it right on position, and that will further confirm that it's the spring that's preventing it from working right. It usually affects downshifting not up shifting!
                    • Orange4
                      • Sep 2013
                      • 398
                      Well the spring seemed fine but what I did find was that the shift lever #1 was welded on to the shift shaft slightly off 90° so that it was not lined up properly at the shift lever #2. It may have slipped off in certain circumstances and become misaligned.
                      There was about 1.5mm of end play on the shift shaft which might have been enough to allow it to slip off. I did find the wear marks to be right near the edge of the shift lever gears and some edge rounding as evidence of the misalignment. Also seems to explain the random shift lever behaviour.
                      I'm not yet 100% sure but it did shift properly when I had the cover off. I have not reassembled yet.
                      Living to EXcess.
                        • 2009
                        saw some parts on Ebay
                        Might be what you need... JAT.
                        http://www.ebay.com/sch/i.html?_odkw...+gear&_sacat=0
                          If your referring to the shift pawl shaft like I think you may be doing, any end-play in that IS a result of the circlip coming off the other side(clutch side). That results in the idler gear that runs the oil pump to fall off shaft and kinda float around. Good side of that, is it's captured behind the clutch assembly and still engages with oil pump gear. If initially what I stated is correct, that clutch side cover needs to come off for closer inspection.
                            BTW, if that be the case, do NOT re-use that circlip.
                            • Orange4
                              • Sep 2013
                              • 398
                              There was less end play on the second lever and it had its circlip, I will take a quick Check on the clutch side.
                              Living to EXcess.
