Clutch Lever pull,,??
  • L.A.
    • May 2014
    • 15
    • Cheyenne, WY.
    I'd like to ease my clutch pull to "real easy",,
    It's not bad now, but I broke my wrist a few years back and since I've started
    riding again, I've found my wrist getting sore, stiff and even swelling.
    Do you know of any simple mods or tricks?
    XJ1100
    Thanks,
    L.A.
    82 XJ11
    Be surprised what a difference a new clutch cable will make.
      • 4013
      Dunno how true it is or not, but a dealer told me the MP cables have a different plastic that allows the cable to slide better.
      • WMarshy
        • Apr 2009
        • 2402
        • Mexico NY
        Hydraulic clutch mod... look it up in the mod section of the forum.
        '79 XS11 F
        Stock except K&N
        '79 XS11 SF
        Stock, no title.
        '84 Chevy K-10 "Big Blue"
          • 2007
          lube it
          with some good graphite based lubricant. It makes a difference, might not be enough for you with the injured wrist, but it made mine easier to pull. The manual says to just use some 30w oil but I like the graphite stuff.
            Doesn't really change pull pressure to disengauge clutch.
              In a green can, Cable Life cable lube sprayed down in a new MP clutch cable before installation is magic.
              • Tdog
                • Apr 2006
                • 67
                • Bradford Ontario Canada
                leverage
                Hi L.A.
                you could also try lengthening the small lever behind the clutch cover that the cable attaches to...or fab a replacement so you ca re-install the original later if you don't like the feel...Don't add too much as the action changes.
                Tdog
                '81 H
                • donebysunday
                  • Oct 2012
                  • 1737
                  • New Berlin, Wi.
                  Slick 50 1 Lube
                  XJ1100
                  Thanks,
                  L.A.
                  I love this Slick 50 1 lube, it seems to last for years. Much cheaper than Tri
                  Flow or
                  Dura lube, cables, chains anything that has friction.
                  76 XS650 C ROADSTER
                  80 XS650 G Special II
                  https://ibb.co/album/icbGgF
                  80 XS 1100 SG
                  81 XS 1100LH/SH DARKHORSE
                  https://tinyurl.com/k6nzvtw
                  AKA; Don'e, UD, Unca Don'e
                    Flow or
                    A cable lube thread............seriously.
                    Ridng more resolves that.........really, it does.......
                    • ViperRon
                      • Feb 2011
                      • 1062
                      • Woodstock, VA
                      Some time how the cable is routed can cause the cable to bind against its case. With some cables the lining on the cable is soft and when its in a bind. In a short time the cover will bind in the casing mainly causing issue when pulling. If you put weaker springs in clutch it will slip under load better to do hydraulic mod or lengthen the leaver under the case than reduce spring pressure.
                      Rodan
                      1980 G Silverbird
                      1198 Overbore kit
                      Grizzly 660 ACCT
                      Barnett Clutch Springs
                      R1 Clutch Fiber Plates
                      122.5 Main Jets
                      ACCT Mod
                      Mac 4-2 Flare Tips
                      Antivibe Bar ends
                      Rear trunk add-on
