drive train noise...sloppy...
  • wjw11teen
    • Mar 2014
    • 93
    • Valleysprings.S.DAK
    hey fellas
    new problem
    cruising around 1st or 2nd kinda idling around my trans or mid drive howels like an old school bus tranmission going in reverse..i used amsoil heavy gearoil in mid drive and castrol 20/50 in gearbox.. i have 1100miles on the mid drive and final drive oil now
    i also notice a harmonic like an out of balance shaft sound when cruising slow speed
    i serviced the final using moly lube and amsoil heavy gear...it all recieved a thorough cleaning
    also seems to be a bit noticeable gear play perhaps the damper is bad?
    this is an 81 xs 1100 special with 19000miles
    what other oils are recommended? any one use lucas products in mid and final drive?
    81 SH gifted to SON
  • WMarshy
    • Apr 2009
    • 2402
    • Mexico NY
    Just curious, how did you clean the final drive? You can move the rubber boot back and check your u-joint... Sounds like you are using a good oil but the noise would concern me. Most poeple use conventional 80/90 hypoid oil or anything between it and a full synthetic 80W/120 oil...
    BTW just to clearify, the transmission on these share the engine oil (20/50). The middle drive and final drive take the same kind of gear oil... Hope you didnt put 20/50 in your middle drive... contrary to that, hope you know you have a middle drive that needs to be drained and replaced.
    '79 XS11 F
    Stock except K&N
    '79 XS11 SF
    Stock, no title.
    '84 Chevy K-10 "Big Blue"
      Correction(no offense W Marshy), full synthetic equivelent to conventional hypoid IS 75-140w syn., Royal Purple, etc. That equivelance is referance to 'cling' factor and 'pound out' resistance......two most important factors with high load presures.
        • 9980
        I use full synthetic 75/140 in the middle and final drives. It quiets them a bit and they run a lot cooler.
        The straight cut gears in these transmissions are noisy by nature, especially in the lower gears.
        Everybody is a genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is stupid.โ€
        โ€• Albert Einstein
          +1......changed both before headin' to rally as I hadn't done it for a few yrs.(obviously don't ride it much/enough), plus with almost nil humidity majority of time, any moisture content would be minimal. Had 75-140syn. in both, but had just enough RoyalPurple left to do one or the other. The syn. went in the middle drive, and had a bottle of Lucas Heavy Duty Hypoid 80w-90 that went in the final drive.
          A slight whine returned, I'm sure from the final drive at constant highway speeds like it used to sound from new. That whine IS from friction, which obviously creates the rise in assemblies temperature. IMO, not enough additional wear that it would'nt outlive rest of bike anyways.
          The capacity of both is small enough, the additional cost of syn. is minimal, and get the added benifit of reduced wear......just because.
          • wjw11teen
            • Mar 2014
            • 93
            i discovered that my u joint is on its way out...its not toast yet but not great either..
            can someone lead me to a link for a new one?..i have an 81 special..thanks...
            81 SH gifted to SON
              • 1796
              No longer sold by Yamaha
              But here is a new one on Ebay. A little pricey... http://www.ebay.com/itm/like/301229744186?lpid=82
                • 8637
                Probably get a couple of good ones from parts guy Andreas.
                These guys used to carry new ones for XS11, you could call them...
                โ˜ฎ
                • WMarshy
                  • Apr 2009
                  • 2402
                  • Mexico NY
                  No offense taken, wasn't quite sure what the synthetic equivalent was because I don't use it. IIRC the semi-synthetic (blend) is a 75-120...maybe, could be wrong again just going on memory.
                  Either way, I've noticed a dramatic improvement with just going with the blend.
                  '79 XS11 F
                  Stock except K&N
                  '79 XS11 SF
                  Stock, no title.
                    Was also just pointing out that 80w or similar in synthetic is NOT equivelant to the same vecosity in synthetic! If your gonna replace conv. hypoid gear oil with synthetic, it NEEDs to be the 70-75/140w. to be equivalent in 'cling' AND 'pound out' capability.
                    Would imagine if you just 'rat' around locally on bike, would'nt matter much.
                    LD riding.........a whole different scenario, and have seen the EVENTUAL end result if not 'stepped' up to the 75-140w, if using synthetic.
                      • 7607
                      A Precision 392 U joint is the part you need to replace the joint.
