What happened?
  • Giggity
    • Mar 2009
    • 113
    • Longmont, CO
    What happened?
    So I picked up my '79 standard today after it had some carb wok done. Trailered it home about 5 miles in the rain. Got it in the garage, started right up and turned the key off. Still running. Hit the Engine Stop switch, still running. Switch off, key out, still running. Finally had to disconnect the battery to get it to stop.
    Thoughts?
    1979 XS1100 Standard
    Putting it together........
  • jwhughes3
    • 2798
    • Home of the Alamo
    Weird.
    Maybe it was hotwired?
    John
    '81 XS1100H - "Enterprise"
      Thoughts?
      That is just SO wrong!..........whatever happened to "I've tried everything, and still can't get it to run".
        I don't know....
        Some things surely have been bypassed. I think I would be giving whoever it was that did your carb work a call.
        • Giggity
          • Mar 2009
          • 113
          • Longmont, CO
          Forgot to mention everything worked fine before it got rained on. I'll let it dry out for a couple days then see what happens.
          • hamjam
            • 1003
            • Toronto ontario Canada
            check the ignition switch wiring connector for a short or full of water to make it short
            Seamus Ó hUrmholtaigh
            Niimi Moozhwaagan
            NOTICE: No trees were destroyed in the sending of this message. We do concede, however, that a significant number of electrons may have been inconvenienced.
            Any connection between your reality and mine is purely coincidental.
            Member of "FOXS-11" (Former Owner of XS-11)
            and SOXS
            2008 Nomad "Deja Buick'
            • donebysunday
              • Oct 2012
              • 1737
              • New Berlin, Wi.
              Wd40
              Don't have to many uses for WD40 but one of them I was shown 45 years ago ,,,,, it's a great moisture displacer might give it a try ?
              76 XS650 C ROADSTER
              80 XS650 G Special II
              https://ibb.co/album/icbGgF
              80 XS 1100 SG
              81 XS 1100LH/SH DARKHORSE
              https://tinyurl.com/k6nzvtw
              AKA; Don'e, UD, Unca Don'e
                +1. Time to open the ignition switch itself and clean out the connections too. Cover them with dielectric grease to protect them from moisture.
                • mack
                  • 2411
                  • Ontario, Canada
                  Jotd
                  now thats funny
                  mack
                  79 XS 1100 SF Special
                  HERMES
                  original owner
                  81 XS 1100 LH MNS
                  SPICA
                  78 XS 11E
                  IOTA
                  https://youtu.be/wB5Jfbp6SUc
                  https://youtu.be/RaI3WYHSuWA
                  Frankford, Ont, Canada
                  613-398-6186
                  • Giggity
                    • Mar 2009
                    • 113
                    • Longmont, CO
                    Did this. All is back to normal now. Thanks!
