Petcock to tank O-ring gasket ??
  • L.A.
    • May 2014
    • 15
    • Cheyenne, WY.
    I've been working on the Xj1100 I recently acquired and am very close to "Ready to Ride"
    I had a petcock leak so I pulled them and found the washers on one petcock drain screws missing. I replaced them with plastic ones,,(Will they work for long?),,,cleaned everything, bent the washer spring a little and put back on.
    Well,,it now leaks at the tank. I'd like to get this running while I wait for petcock rebuild kit.
    So here's the question,,
    The 0-rings are still in one piece, but some cracks and what looks like rust.
    I'm soaking them in ArmorAll.
    If I put them back in, maybe with some Right stuff or YamaBond, do ya think they will seal for a while or am I asking for trouble??
    It's sure hard to have to wait when I'm so close
    82 XJ11
    • 8798
    Get some round ones at local hardware store, they should fit right in there with minimal effort. Put a couple small dabs of RTV to hold them in place while fitting the fuel tap.
      • 5062
      Make sure the bolt washers/gaskets are in good shape, else fuel will leak down the bolt threads.
      • mikubuilder
        • Jul 2011
        • 548
        • Westland, Mich.
        Yeah, mine are leaking at the screws, you have to get the right fiber washer to stop that leak
        Nick
        1982 Virago 750 (it's alive!)
        • L.A.
          • May 2014
          • 15
          • Cheyenne, WY.
          I did find some o-rings at Menards that will fit and some fiber washers.
          How much do I need to worry about these plumbing o-rings & fuel?
          Nobody carries the viton type, they have to be ordered.
          Even the autoparts stores don't carry them here.
          82 XJ11
            • 8798
            Most standard O-rings are made of nitrile rubber which will hold up to fuels. You should be ok, keep an eye on them just to be sure.
              • 5062
              One more thing...use the OEM flanged bolts without adding metal washers (only use the fiber ones), or the gas will seep.
              • L.A.
                • May 2014
                • 15
                • Cheyenne, WY.
                Thanks All,
                I did buy new screws,,One of the original flanged ones is starting to round (phillips),,I'll use the old ones.
                For anyone looking, The o-rings that appear to fit are, 1 1/4 id, 1 7/16 od, x 3/32 wall.
                I'm headed out to put it all together,,,Keep your fingers crossed please,,I need all the help I can get!!
                L.A.
                Xj1100
                82 XJ11
                  • 1911
                  just buy oem new ones from
                  MRCycles http://www.mrcycles.com/ or Partspak http://www.partspak.com/productcart/...sp?message=212 . They are not expensive. You can get the o rings washers and new screws if necessary.
                  Some things are not worth cutting corners on just to save 2 or 3 dollars. Where there is gas involved be safe and do the job right.
