Starter disassembled, what to wash it in?
  • Courtney
    • 542
    • Nanaimo BC Canada
    Little leary about washng the starter windings etc in my solvent tank. Looked for James_Englands starter rebuild tutorial but couldn't find it. I'm thinking brake cleaner might be inert enough to not damage insulation on the windings/wires inside the starter??
    Bone stock 1980 Special except for the exhaust and crashbars. Oh yeah, and the scabbard for the Winchester Defender.
    Everything emmersed in a solvet tank and brushed clean will NOT hurt a thing.
      • 8802
      Here you go Courtney....
      • Courtney
        • 542
        • Nanaimo BC Canada
        Thanks Phil! Read it over, and love that I can just soak it in my solvent tank and use a toothbrush carefully.
        • Courtney
          • 542
          • Nanaimo BC Canada
          Thanks Motoman! It's soaking now overnight.
          • James England
            • 3039
            • North of England
            For a quicker result, you can always use carb cleaner in an aerosol......
              • 5062
              James, I had carb cleaner on my fingers once and answered the telephone. It disolved some plastics - like telephone receivers. I use that stuff on a lot of things, but anything with electrical insulation is out of the question for me! I know, YMMV!
              • Courtney
                • 542
                • Nanaimo BC Canada
                I ended up using brake cleaner which is just dry cleaning fluid, aka perchloroethylene. It was developed during the second world war to degrease small arms and other stuff. It is pretty easy on things, as you can imagine if you can use to clean brake parts, rubber etc. Worked like a charm. :-)
                • D0wn5h1ft
                  • Aug 2013
                  • 515
                  • Westerly, RI.
                  Wire insulation is about half and half made of either polyethylene or PVC. Polyethylene has an OK resistance to keytones (acetone aka carb cleaner) and PVC has a not so good resistance to keytones (especially acetone). In weak concentrations, pvc can be exposed to acetone with little to no effect but exposing it to high conceneration can and will dissolve the PVC wire insulation.
                  Long story short, using carb cleaner on your starter if it has PVC wire insulation is a poor idea at best.
                  78 E - 2to1 exhaust, dynatek coils, special headlight [SOLD!]
                  79 F - gas tank refurb, headgasket change, straight pipes, late model carbs, virago lowering shocks, special headlight and gauges, TC fuse block, GSXR-1100 carbs (WIP)
                  "May my tires not fail me, nor my engine grow cold"
                  • hamjam
                    • 1003
                    • Toronto ontario Canada
                    So Courtney the consensus is Dove with a Downey rinse I see
                    Seamus Ó hUrmholtaigh
                    Niimi Moozhwaagan
                    and SOXS
                    2008 Nomad "Deja Buick'
                    • Courtney
                      • 542
                      • Nanaimo BC Canada
                      Thanks Hammy, I ended up putting it all in the dishwasher while Gail was out in her workshop making jewelry.
