Syncing Carbs
  • TheRev
    • Jun 2012
    • 235
    • Madison, Wi.
    Syncing Carbs
    Hello All
    Does anyone know if there is a carb syncing process outlined on this forum? I have a sync pro that was loaned to me but I am not sure on a couple of things. Here are some of my questions.
    To calibrate the tool Do I connect the sync tool to the 3rd carb manifold boot or the second?
    after calibration do I connect the sync tool to the carb bodies or the carb manifolds?
    Thanks
    1979 xs1100f
    New Fuse Box
    Progressive Shocks
    Gold Valve Emulator
    Dyna Coils
    Electronic Flasher
    Led Headlight
    Led Turn Signals
    4 Led Driving Lights
    2nd Gear Fix
    Auto Cam Tensioner
    Digital Dash
    Stainless Braided Lines
    R6 4 Piston Calipers
    Stainless Bolt Kit
    Maier Fairing
    Dyna Balancing Beads
    Spin On Oil Filter
    Stebel Nautilus Horn
    Plasti Dip Rims
    ISO Grips
  • MPittma100
    • Aug 2011
    • 2359
    Carb Sync
    This link should help:
    Start here:
    http://www.xs11.com/forum/showthread...sync+procedure.
    If the type of sync tool that you have requires calibration to start the process, you would normally have all four hoses hooked together and calibrate them all to each other from one vacuum port off of any carburetor.
    Mike
    1981 XS1100H Venturer
    K&N Air Filter
    ACCT
    Custom Paint by Deitz
    Geezer Rectifier/Regulator
    EBC Front Rotors
    Limie Accent Moves On In 2015
    Mike
      Originally posted by TheRev
      Hello All
      Thanks
      It's best to use a constant vacuum source to calibrate, I use a hand vacuum pump. This will also make you aware of any leaks if there are any and correct.
      When you calibrate it's not as important that the gauges read accurately as it is that they all read the same under the same vacuum.
      The gauges need to be connected to the boots. Only one carb, (#2) has a vacuum connection and it is ported
      • TheRev
        • Jun 2012
        • 235
        • Madison, Wi.
        Thank you all. That helps a bunch.
        Start here:
        Mike
        1979 xs1100f
        New Fuse Box
        Progressive Shocks
        Gold Valve Emulator
        Dyna Coils
        Electronic Flasher
        Led Headlight
        Led Turn Signals
        2nd Gear Fix
        Auto Cam Tensioner
        Digital Dash
        Stainless Bolt Kit
        Maier Fairing
        Spin On Oil Filter
        Plasti Dip Rims
        ISO Grips
