Bike Stranded
  • donebysunday
    • Oct 2012
    • 1737
    • New Berlin, Wi.
    Bike Stranded
    After dealing with the rear seat rails took it for a ride. 25 mi. out I hit the brake and the lights dimmed. Then it felt like a couple cylinders were missing, died. It's in a gas station right now. Could I have missed hooking things back together after the alignment deal and replacement of the rear end, fender and such ?
    76 XS650 C ROADSTER
    80 XS650 G Special II
    https://ibb.co/album/icbGgF
    80 XS 1100 SG
    81 XS 1100LH/SH DARKHORSE
    https://tinyurl.com/k6nzvtw
    AKA; Don'e, UD, Unca Don'e
  • jjz28
    • Apr 2012
    • 1023
    • Beckley, W. Va.
    I am definitely no guru but it sounds like its not charging. I guess I would check everything I disconnected and see.
    77 XS750 2D completely stock
    • James England
      • 3039
      • North of England
      It looks like a flat battery to me. When you hit the brakes, the lights dimmed which would tend to indicate a low battery and no charging. Then, when the voltage drops to a certain level, the TCI stops working.
      You may find that with a charged battery the bike starts again. If you can start the bike, rev the engine and check that the lights brighten as the revs increase. This will check that the charging system is working....
        I had a rear brake switch short out recently. A bit different than yours. It wouldn't die, but would blow fuses as soon as you hit the brake and lose everything at the dash (Tac, gauges, etc.). I simply unplugged it to get home. Sounds like something shorting to ground to me... but I've been wrong lots of times.
        • James England
          • 3039
          • North of England
          Yes, that would gel with his having removed the rear fender and lights.....
          • donebysunday
            • Oct 2012
            • 1737
            • New Berlin, Wi.
            Me DUMB !
            I set the trip meter when I fill up, 78 mi. showing, I did not think empty. Reserve did not help, (pull the petcocks, which pipe came off). If the light had come on would have clued me (burned out, worked before). Maybe did not top it off as full as I normally do.
            Nice guy heard me cranking every couple of min. (battery good) needed his good deed, gave me a ride, dropped me 12 blocks from my house.
            Pulled the seat, nothing, put in a charged parts bike battery, popped.
            Looked in the tank, out of gas at a gas station !
            E10 I wouldn't run that had real gas can in the car, fired right up.
            Lesson learned again Thank You All !
            76 XS650 C ROADSTER
            80 XS 1100 SG
              I guess that could have been a lot worse.
              • donebysunday
                • Oct 2012
                • 1737
                • New Berlin, Wi.
                I work much cheaper than that though you must be aware of my $hit I forgot
                76 XS650 C ROADSTER
                80 XS 1100 SG
