First, I just bought an 80 midnight last month. Second, I'm slowly doing modern upgrades to make everything run more efficiently. I switched out the fuse box for a blade style box today and I feel like it made a difference.... My next project scheduled for Monday will be running new ground wires from the battery/chassis/block
I know on cars, if you run new, bigger ground wire from the battery to the chassis, the battery to the block, and the block to the chassis, it's called the big 3
Is that a thing with bikes? Should I even worry about it? What gauge should I use?
A couple more questions: should I switch out the main fuse on the left by the battery for a new blade style? Are there any other easy things I can do?
It doesn't slip out of gear like I've read some do. It does, however, not start for a couple hours after it's rained. I didn't know if that's something I should be worried about. I cleaned the carbs two weeks ago, they're good. The bike runs great! I just want to make sure I do some good for it too
