Regrounding the bike
  • Shootoo
    • May 2014
    • 28
    • Salt Lake City, Utah
    First, I just bought an 80 midnight last month. Second, I'm slowly doing modern upgrades to make everything run more efficiently. I switched out the fuse box for a blade style box today and I feel like it made a difference.... My next project scheduled for Monday will be running new ground wires from the battery/chassis/block
    I know on cars, if you run new, bigger ground wire from the battery to the chassis, the battery to the block, and the block to the chassis, it's called the big 3
    Is that a thing with bikes? Should I even worry about it? What gauge should I use?
    A couple more questions: should I switch out the main fuse on the left by the battery for a new blade style? Are there any other easy things I can do?
    It doesn't slip out of gear like I've read some do. It does, however, not start for a couple hours after it's rained. I didn't know if that's something I should be worried about. I cleaned the carbs two weeks ago, they're good. The bike runs great! I just want to make sure I do some good for it too
    80 LG
  • wingnut
    • 695
    • NC
    welcome to the xs11 madness. Your going to like it here. You could and should remove and clean every ground on the bike. Upping the size of the wires isn't really going to buy you anything as the output of the charging system is fairly low and those little guys from Japan did a pretty good job of sizing the wires. Also disassemble every connection and clean it and reassemble using some dielectric grease. I'd also disassemble both controls on the handle bars. The kill switch on the right could be causing your no start when wet issue. The key switch can also be disassembled, cleaned and greased. I'm still running the glass fuses but have replaced the clips. Replacing the main fuse with a blade type is a good idea for pice of mind.
    wingnut
    81 SH (Daily Ride)
    81 XS 400
    Thomas Jefferson
    • MPittma100
      • Aug 2011
      • 2359
      Quote:
      First, I just bought an 80 midnight last month. Second, I'm slowly doing modern upgrades to make everything run more efficiently. I switched out the fuse box for a blade style box today and I feel like it made a difference.... My next project scheduled for Monday will be running new ground wires from the battery/chassis/block.
      You can drastically improve the bike's electrical by configuring the grounds from OEM chassis grounds to direct battery grounds. Start out by adding a wire from where the battery ground cable bolts to the frame. Run another wire from that point to where the engine ground attaches to the frame. Add another ground wire from either of these points up to the regulator/rectifier (under the tank) mounting bolt that already has several ground wires on it. It is also a good idea to run a ground wire from there into the taillight harness atop the rear fender. By doing all of this, every chassis ground has been converted to direct battery grounds. Use 10-12 gauge wire. A smaller gauge can go to the taillight harness. You and the bike will be glad you did this.
      Mike
      1981 XS1100H Venturer
      K&N Air Filter
      ACCT
      Custom Paint by Deitz
      Geezer Rectifier/Regulator
      Stebel Nautilus Horn
      EBC Front Rotors
      Limie Accent Moves On In 2015
      Mike
      • tcoop
        • Nov 2009
        • 793
        • South Weber, UT
        Cleaning every electrical connection and cleaning the controls on the handle bars will most likely solve the no start after a rain. If not I would look at your coils for cracks. I did the wiring upgrade that Mike is talking about and it improved the cranking power on the bike. Rain, shine, bike hot or cold and it has no problem starting.
        By the way, Welcome to the forum from a fellow Utahan.
        Ty
        78 XS1100E - Now in Minnesota
        80 XS1100LG - The Punisher
        82 XJ1100 - Daughter's Bike
          IIRC another wet no start problem source is the wires down to the timing cover, the connectors and such...folks have reported water getting down in there shorting across the wires in the connector.....the PU wires and neutral light and such.
          • Shootoo
            • May 2014
            • 28
            Thanks! Good to see another Utahn. I'm East of you in O town
            The fuel lines are changed out, octy is gone, ground wires set. It runs great. Almost completely different than when I got it 2 months ago!
            I will tear in to the kill switch and key hole tomorrow
            What other mods are there to get it running better?
            80 LG
              Your pretty much 'on it' with what your doing. Ignition switch AND kill switch are known voltage drop areas that need attention. EveaporRust is your friend there. Drop all pieces including switch in some overnite......wa-la... all clean of corrosion and even the red insert of kill switch wil look like new.
              As a side-note, I ride up there least once a yr........just cause I can, to Layton. Makes for a nice ride, going the 'back way' to Vernal, Park City and on down Ogden canyon.
