Xj1100 Float valve ??? O ring??
Try to find Viton "O" rings at Napa. I would replace all 4, as a leak will cause the carbs to flood!
I don't know the exact size, but it shouldn't be that hard to find with a search on carb orings here.
XS1100 SF Bob Jones worked on it! -
If you have purchased an YICS Eliminator from me, you can use 4 of the extra O-rings that come with it to replace those. They are a tight fit, so use a little WD-40 when installing them in the carbs. If you haven't purchased an Eliminator, you will need one to do a proper synch on your carbs. Send me a PM and I will sell you an Eliminator without the eBay fees.
Ride safe,
LarryLast edited by Yahman; 06-23-2014, 03:29 PM.Inventor of the YICS Eliminator. Want one? Get it here.
82 XJ1100
80 XS1100G (Project bike)
64 Yamaha YA-6
77 Suzuki TS-185
See it here... http://www.youtube.com/watch?v=cBYT4C9_6AcComment
Thanks,
I have been searching for the Viton o ring size,,haven't had great luck yet.
One post suggested m1.5 x 7,,,,,I googled viton o ring m1.5 x 7 with no success. I'm not really sure what I'm looking for, I guess,,
I really want to know what I need as I'm 20 miles from town, and can't be making several trips back & forth..
Thanks Larry, I haven't purchased one yet, but I've have been reading up on your Yics tool,,Quite impressive,,I intend to soon and will Pm you then,,
Again Thanks all,
Little side history,,,,I had a xj750 in the late 80s & 90s, but I always had it serviced at the Yamaha dealer and never learned how to do these things myself.
I got the xj1100 a few weeks ago,,The Yamaha dealer, (The old one I used before closed down),,Informed me they won't do any work on bikes over 10 years old!!!???,,,,so here I am and very thankful I found you guys,,82 XJ11Comment
Found these here h ttp://www.amazon.com/M1-5x7-Viton-O-Ring-Shore-Durometer/dp/B005RUPE8Q/ref=sr_1_2?s=industrial&ie=UTF8&qid=1403575646&sr= 1-2 .BDF Special
Dyno tuned to 98 hp at the rear wheel.Comment
Thanks for the reminder there are extras buried somewhere in my garage, Larry
It's good practice to lubricate every o-ring you install. In my mind, there isn't a whole lot WD-40 is good for these days, but lubricating o-rings is one of them (only use brake fluid for brake components, though!).82J · 81SH · 79SF Fire Damage · 78E · 79F Parts Bike · 04 Buell Blast
Website/Blog
Harbor Freight sells a large assortment of viton o rings in a box, for about eight bucks.
Some of them you will never use on any motorcycle, however there are a few sizes in the assortment that work perfect for petcock and octy diaphragm tip o rings and needle seat o-rings.Howard
ZRX1200
Seca 750Comment
