Xj1100 Float valve ??? O ring??
  • L.A.
    • May 2014
    • 15
    • Cheyenne, WY.
    Cleaning my carbs (1st time for me),,and discovered this on one of the float valves.
    Is this a O-ring I can purchase at napa or someplace or do I have to try to find new ones?
    82 XJ11
    Try to find Viton "O" rings at Napa. I would replace all 4, as a leak will cause the carbs to flood! I don't know the exact size, but it shouldn't be that hard to find with a search on carb orings here.
    • Yahman
      • Mar 2008
      • 779
      • Salem, OR
      If you have purchased an YICS Eliminator from me, you can use 4 of the extra O-rings that come with it to replace those. They are a tight fit, so use a little WD-40 when installing them in the carbs. If you haven't purchased an Eliminator, you will need one to do a proper synch on your carbs. Send me a PM and I will sell you an Eliminator without the eBay fees.
      Ride safe,
      Larry
      82 XJ1100
      80 XS1100G (Project bike)
      64 Yamaha YA-6
      77 Suzuki TS-185
      • L.A.
        • May 2014
        • 15
        • Cheyenne, WY.
        Thanks,
        I have been searching for the Viton o ring size,,haven't had great luck yet.
        One post suggested m1.5 x 7,,,,,I googled viton o ring m1.5 x 7 with no success. I'm not really sure what I'm looking for, I guess,,
        I really want to know what I need as I'm 20 miles from town, and can't be making several trips back & forth..
        Thanks Larry, I haven't purchased one yet, but I've have been reading up on your Yics tool,,Quite impressive,,I intend to soon and will Pm you then,,
        Again Thanks all,
        Little side history,,,,I had a xj750 in the late 80s & 90s, but I always had it serviced at the Yamaha dealer and never learned how to do these things myself.
        I got the xj1100 a few weeks ago,,The Yamaha dealer, (The old one I used before closed down),,Informed me they won't do any work on bikes over 10 years old!!!???,,,,so here I am and very thankful I found you guys,,
        82 XJ11
        • tinman905
          • Aug 2007
          • 946
          • Orangeville,Ontario ,Canada
          Found these here h ttp://www.amazon.com/M1-5x7-Viton-O-Ring-Shore-Durometer/dp/B005RUPE8Q/ref=sr_1_2?s=industrial&ie=UTF8&qid=1403575646&sr= 1-2 .
          BDF Special
          • Prothec
            • Jul 2007
            • 587
            • Fort Myers, FL
            Thanks for the reminder there are extras buried somewhere in my garage, Larry
            It's good practice to lubricate every o-ring you install. In my mind, there isn't a whole lot WD-40 is good for these days, but lubricating o-rings is one of them (only use brake fluid for brake components, though!).
            Website/Blog
              • 3372
              Harbor Freight sells a large assortment of viton o rings in a box, for about eight bucks.
              Some of them you will never use on any motorcycle, however there are a few sizes in the assortment that work perfect for petcock and octy diaphragm tip o rings and needle seat o-rings.
              2001 ZRX 1200
              1982 Seca 750
              1983 Nighthawk 550
